rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
Can't get tranny drain plug out. OK to pump from fill hole?
I've tried heat, leverage, PB Blaster, searches, etc. but can't get the transmission drain plug out. Is it okay to pump it out from the fill hole with which I have no problem?
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 08-12-2006, 03:20 AM
ruf-porsche's Avatar
O.K, but doubt if you will get all the tranny oil out.
Old 08-12-2006, 03:53 AM
rs6er's Avatar
Well. You can't get all the motor oil out either.
John
Old 08-12-2006, 04:32 AM
With the gears in the way it will be difficult. That said, feel the oil you are removing by rubbing between your fingers and try and determine how much metal there is in there. That would be my concern by only removing about half the oil and leaving the metal mixed in with new oil. That plug will come out, even if you need to take it to a shop to have it cracked loose for you. Better to get all the old oil out IMHO.
Tony G
2000 Boxster S
Old 08-12-2006, 05:14 AM
rs6er's Avatar
Thanks. I think I'll follow your suggestion. I had a warm transmission, the proper allen socket from our host being pressed into the plug by a floor jack o it couldn't shift, a long pipe on the end of a breaker bar, and I couldn't get it to budge. I am afraid of stripping the plug (or worse!)
John
Old 08-12-2006, 05:24 AM
There is a shop near Ryebrook, an Exxon station I think, and I have seen all kinds of very expensive cars being worked on there. If I remember right, it is that Playland Park at exit 20 or 21, last one before CT on 95.
Tony G
2000 Boxster S
Old 08-12-2006, 05:35 AM
rs6er's Avatar
Thanks. I know where I can take it locally for a job like this.
John
Old 08-12-2006, 06:22 AM
charleskieffner's Avatar
use ingersoll rand 3/8 impact ratchet. with mega compressor it will come off! mine was a PITA imean a REAL PITA!!!! cheater bar etc. finally I/R 3/8 ratchet did it. good luck.
Old 08-12-2006, 06:39 AM
Semper drive!
rcecale's Avatar
Probably a silly question, and I sincerely am not trying to insult your intelligence, but are you sure you're "loosening" it in the correct direction? "Righty-tighty, lefty-loosey"
Randy
84 944 - Alpine White
86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten )
One Marine's View
Igitur qui desiderat pacem, praeparet bellum
Old 08-12-2006, 07:34 AM
durn for'ner
livi's Avatar
Yup, that was the worst project so far in my book. I had to manufacture a home made breaker bar that was almost 1 meter long to get enough momentum on that bugger.
The PO with the gorilla hands have since then been 'corrected'..
Markus
Resident Fluffer
Carrera '85
Old 08-12-2006, 09:30 AM
For a real local shop...this is gonna sound crazy, absolutely crazy, but here it goes, take it to one of the 15 minute oil change places with your tool and a breaker bar, ask them if YOU can try to get the trans plug loose. Tell them you will pay the 18.99 for a trans service if you must. Being able to stand up and having the car sitting on its tires is a definite plus. Leverage and stability = torque, which = loose drain plugs. The bay wall is an excellent place to gain leverage,better than a Lift,(imo) but will be OILY, so bring a spare set of shoes and shirt...Worth less than two cents but always worked for me and all my old beetles(17mm Allen)... GOOD LUCK
1981 911 SC (Slowly but surely)
1966 MG 1100 (Its worse than you could imagine)
Old 08-12-2006, 10:09 AM
rs6er's Avatar
Randy
Not offended.
John
Old 08-12-2006, 10:38 AM
If you're putting motor oil in your tranny you have other problems.
Old 08-12-2006, 01:50 PM
rnln's Avatar
Randy
I happend to me, not tranny drain plug but other part. The result is beating myself for days.
Fat butt 911, 1987
Old 08-12-2006, 05:06 PM
John,
Have you tried ah, tapping, the breaker bar with a 5 pound hammer.
Ned NYNA 11
87 Carrera targa
98 BMW 528i
98 Volvo V70
Old 08-12-2006, 06:16 PM
rs6er's Avatar
As I said, I'm afraid of stripping the plug.
John
Old 08-12-2006, 06:20 PM
