Guest
Posts: n/a
mystery tool
I am the new owner of my second '88 Carerra coupe. I found the tool in question in the glove box. It is a small (1.5in.long) black plastic dowel. The knurled handle end is @3mm dia. and the other end is a smaller hex shape @1.5mm. The car has always been kept extremely original by a very picky previous owner. If I had to guess, I'd say it had something to do with the Reno radio- but for all I know it may be the wind-up key for a talking Barbie. I enjoy the forum greatly. Thanks in advance. -Ray
Guest
Posts: n/a
Just a suggestion without having a good picture of your tool in mind:
May be it is for pulling the antenna, if completely lowered? If you have an electric one-just forget this note. |
Guest
Posts: n/a
I replaced my Reno radio last fall and I recall having that item in the parts ,I think, of my new radio. I could not account for its use and put it in the box when I put it away. I think it is use for some type of adjustment on the back of the radio, but another tool works, hence the confusion of its purpose. If is is really important, I will dig it up and try to figure it out for you. Do not worry, it is not the key to the universe. Michael
Guest
Posts: n/a
Thanks for the feedback guys. Michael was in fact, correct about the tool. I scoured my radio owners manual and discovered the tool is used for a minor adjustment on the underside of the radio having to do with traffic reports. Can't imagine I'll ever need it unless the universe is in need of adjustment. Thanks. - Ray
Guest
Posts: n/a
si a radio adj tool
