goldsc78258's Avatar
Send a message via Yahoo to goldsc78258
anybody near San antonio tx have a 3.2 motronic I can borow?
I have tried everything and I think the computer is bad on this 3.2 swap. I need to find one I could try to see if it is what is wrong. Anybody near or in san antonio?
Help
Fred
Old 09-06-2006, 11:50 AM
I'm sure Jones Autowerks has one...
1989 Carrera Targa - - Guards Red
Old 09-06-2006, 12:12 PM
DW SD's Avatar
Fred,
Can you check that the ground to your computer has a good contact? Take a look at the harness going into the computer and look for the brown wire(s). Check continuity to ground. If you had a bad ground, I bet you'd possibly have problems, too.
I know the DME relay has at least one ground going to it. If it is indeed giving power to the computer, its ground must be working.
Just another avenue to explore.
I don't know where the grounding points are in your car.
Doug
1971 RSR - interpretation
Old 09-06-2006, 12:18 PM
Yes doug, I checked the one on the realy but not the one on the computer I'll do that.
I can't believe I can't solve this it is really kicking my a$$$
Buffjamr I called jones and they didn't have one
Fred
Old 09-06-2006, 12:22 PM
yep I have the wire with a good ground but nothing
Fred
Old 09-06-2006, 12:35 PM
IT IS RUNNING!!!!
And yes I was yelling
Thanks aeverybody that chimed in. specially Doug
Fred
Old 09-07-2006, 11:17 AM
