MMBRAZIL
Guest
Posts: n/a
hot again
The timing is ok, nothing wrong with the external cooler, valves ok.....so where more to look?
Traffics 120°c, free run 100°c....this is getting me crazy.....help!!!!!!
Old 03-21-2000, 12:37 PM
jryerson
Guest
Posts: n/a
Their are many places to start,
Does your car have a front fender oil cooler?
If not some 911s just run hotter and need to have one
Fanbelt slipping?Do you have the upgraded fan?
I took my alternator/fan off the shroud and cleaned and inspected the top of the heads While in there I also checked the air channels in the shroud for any blocking(I had some grease in mine)I also ran a garden hose thru the channels and watched for free flowing water thru the engine oil cooler out the bottom
Any pinched oil lines ?It takes a severe pinch to restrict flow ,
I even had one , obviously from a idiot jacking the car in the wrong spot ,it was flattened a bit but not enough to cause a problem.
Old 03-21-2000, 09:10 PM
MMBRAZIL
Guest
Posts: n/a
jryerson,
I have the 11 blade fan, have the cooler...I will follow the channel checking....and keep you posted. tks....
Old 03-22-2000, 05:42 AM
jabb
Guest
Posts: n/a
When the car is hot is the cooler getting
hot also. If the cooler is not hot then the
thermostat is not opening to circulate the
oil to the cooler.
Joe A
Old 03-22-2000, 06:03 AM
MMBRAZIL
Guest
Posts: n/a
yes, the cooler is ok....
Old 03-22-2000, 10:03 AM
