rear quarter pop-out windows
hello all,
i love the look of the rear quarter pop-out windows on the older cars. i think i've seen them mostly on 72-76, i'm really not sure on the years, but do you think these pop-out versions are interchangeable? Would they fit on my 78 930? Also, is it likely that the factory tints will be different between those years and mine, i just want to make sure they would blend in. best, paul. if they're viable, does anyone have a set L and R, for sale?
78 930 84 R5 T2 04 Suby Outback "it's a mystery, wrapped in a riddle, inside an enigma" Winston Churchill. |
The popout window will fit and there are numerous and extensive threads about installing them on later cars. Worth doing a search. In short you need to gather the windows, seals, trim pieces and latch. To install them you will need to remove a welded metal piece from the B-pillar to expose the hinge mounting slot. There are a clear and blue tinted windows out there so that will be worth deciding what you want. The blue windows seem to be a bit more rare.
I have two right-hand side windows/frames with clear glass available with hinges. I do not have the lower trim pieces.
gary |
ah, thanks for the explanation Gary.
i did a search for pop-out window, but will try a more general search and find these threads. my windows have the blue tint, which i really like. i'm getting some body work done on the rear right fender, so the quarter window is coming out. so i figured i should do the switch at that point. appreciate the help. best, paul.
look in this link and follow the other threads mentioned. Should tell you just about everything.
Good luck Rear quarter window Modification
gary |
thanks Gary. i should start learning to use the boolean features in my searches....looks like there's absolutely tons of recent stuff out there.
best, paul.
Gary, just sent you a pm.
Replied
gary |
