rear quarter pop-out windows
hello all,
i love the look of the rear quarter pop-out windows on the older cars. i think i've seen them mostly on 72-76, i'm really not sure on the years, but do you think these pop-out versions are interchangeable? Would they fit on my 78 930?
Also, is it likely that the factory tints will be different between those years and mine, i just want to make sure they would blend in.
best, paul.
if they're viable, does anyone have a set L and R, for sale?
84 R5 T2
04 Suby Outback
"it's a mystery, wrapped in a riddle, inside an enigma" Winston Churchill.
Old 07-12-2006, 08:25 AM
The popout window will fit and there are numerous and extensive threads about installing them on later cars. Worth doing a search. In short you need to gather the windows, seals, trim pieces and latch. To install them you will need to remove a welded metal piece from the B-pillar to expose the hinge mounting slot. There are a clear and blue tinted windows out there so that will be worth deciding what you want. The blue windows seem to be a bit more rare.
I have two right-hand side windows/frames with clear glass available with hinges. I do not have the lower trim pieces.
gary
Old 07-12-2006, 09:16 AM
ah, thanks for the explanation Gary.
i did a search for pop-out window, but will try a more general search and find these threads. my windows have the blue tint, which i really like. i'm getting some body work done on the rear right fender, so the quarter window is coming out. so i figured i should do the switch at that point.
appreciate the help.
best, paul.
84 R5 T2
04 Suby Outback
Old 07-12-2006, 10:53 AM
look in this link and follow the other threads mentioned. Should tell you just about everything.
Good luck
Rear quarter window Modification
gary
Old 07-12-2006, 11:51 AM
thanks Gary. i should start learning to use the boolean features in my searches....looks like there's absolutely tons of recent stuff out there.
best, paul.
84 R5 T2
04 Suby Outback
Old 07-12-2006, 12:20 PM
Gary, just sent you a pm.
84 R5 T2
04 Suby Outback
Old 08-14-2006, 11:23 AM
Replied
gary
Old 08-14-2006, 12:36 PM
