Carbon Emitter
jkarolyi's Avatar
Capacity of oil tank alone
A quick search didn't turn up an answer for me. I changed my oil on my '73 911E only about 1,000 miles ago, but had to fix an oil leak in the oil tank. I only drained the oil tank, not the crankcase. Approximate how much oil should I add?
Old 08-20-2006, 12:28 PM
It depends....
Cars with a front oil cooler typically have a total capacity of 13 qts... with a refill capacity of about 9-10. If the car was recently run and warm...about 6 or so comes from the tank and 3 or so comes from the engine. If the engine is cold ( wasn't run recently), then most of the oil drained back into the engine case and the values are reversed...about 3 comes from the tank and 6 from the engine...
Keep in mind also that cars without front coolers have a total system capacity of about 9 qts...not 13.
Here's a question...why didn't you transfer the "taken out" oil into a clean milk gallon jug.....then just add back what came out? You'll know what came out. I advise this all the time for the oil change question threads......
- Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 08-20-2006, 12:54 PM
Carbon Emitter
jkarolyi's Avatar
My oilpan is very dirty and has had some really nasty oil/dirt/sludge in it, so I didn't want to re-use contaminated oil. Its the enclosed kind of oilpan that is nearly impossible to clean.
Thanks for your help!
Old 08-20-2006, 01:18 PM
I think what he is saying is, by using the gallon milk jugs you will know how much came out of the tank 1 gal =4quarts
Old 08-20-2006, 01:20 PM
dan79brooklyn's Avatar
measure the amount of OLD oil you drained out and add that amount of NEW oil
Current Drivers - 2006 BMW 1 Series & MB E320 Wagon
(new addition 1998 Mazda Roadster)
EX - 1993 Porsche 911 Carrera 2
EX - 1979 Porsche 911SC TARGA
EX - 1976 BMW 2002
Old 08-20-2006, 01:21 PM
I think that is what we both just said!!
Old 08-20-2006, 01:25 PM
Carbon Emitter
jkarolyi's Avatar
Ah, I see, thanks guys. I drained the oil into the same pan with the old oil from my girlfriend's Honda, so measuring it wouldn't work too well. I just added three quarts (engine was cold when I drained the tank) and the oil level was near perfect once warm!
Old 08-20-2006, 01:58 PM
