Serge
Guest
Posts: n/a
Antenna
How do you install an antenna in a 911?
Old 03-24-2000, 04:11 PM
Andras Nagy
Guest
Posts: n/a
Serge:
You did not mention which model and year you have, but generally one just inserts the antenna from the outside in through the hole in the fender (if your car has the fender mounted kind), and then you'll have to thread the antenna lead through the bodywork (generally through a rubber grommet), into the interior of the car, and up to your radio. Don't forget the electrical lead for the power (if it's a powered antenna).
However, if you have the window-encased antenna, then there should be pre-wiring for that, since the antenna wires are laminated between the glass.
If you have more specific questions, ask away......Andras
Old 03-27-2000, 05:36 AM
