Dug Shannon
Guest
Posts: n/a
Wheel locks
I have a set of wheel locks on my '81 SC that are about 20 years old.
The jerk at Goodyear used an impact wrench fixing a flat tire and sheared all of the drive pins off of the key.
This lock was popular about twenty years ago - it is the one with the five, irregularly spaced, .125" diameter drive pins.
I need a new key. My key number is 5K but I can't locate the company that made it. I don't know if they are still in business.
Any help would be appreciated.
Old 03-24-2000, 06:07 PM
Early_S_Man
Guest
Posts: n/a
Those are Garretson Enterprises locks, and they are out of business, sadly. I would suggest emailing Bruce Anderson for ideas, as he was with GE back then, and may know who might help you. As a last resort, take the old key with sheared pins to a machine shop, and see if they can rebuild it. I think you now understand why I get homicidal thoughts about idiots with impact wrenches even approaching my car!!!
Warren Hall
1973 911S Targa
Old 03-24-2000, 06:19 PM
Superman
Guest
Posts: n/a
To get those locking things of without a key, you can sometimes drive the right sized 12-pt socket onto it and get it off that way. Ruins the socket though, probably.
The ones I have maintain a place you can call for new keys. Perhaps for less than you'd pay to rebuild your key.
Old 03-26-2000, 08:56 AM
rbeech
Guest
Posts: n/a
I had the same problem myself. One piece of advice I received was "once these locks are removed, throw them as far as you can." I finally found that Automotion sells the keys individually. Part# WL-901.
Ron
69 911E
Old 03-27-2000, 11:03 PM
