-   -   Twisty shifter -- need help (http://forums.pelicanparts.com/porsche-911-technical-forum/298984-twisty-shifter-need-help.html)
BR-549 08-16-2006 07:25 AM
All of a sudden, the gear shifter on my 73.5 911T has started to twist inside the casing that it fits in. For example, when I push it over to the right to get into R or fifth, the top end of the shifter will spin counter-clockwise a bit, or pulling it toward me to downshift into second it will spin clockwise a little.
Anybody seen this problem? Any suggested fixes?
Thanks.
Ken
JWest 08-16-2006 07:48 AM
The factory epoxy has let go.
Clean well and epoxy it back for another 30 years of service, or remove, refurbish, and weld if you want a more permanent fix.
BR-549 08-16-2006 08:52 AM
Thanks James. When I re-align the shifter, does the "clip" (i.e. the bent piece of metal on the right side that engages the reverse lock-out) point to the exact right center? Any good way to get that alignment straight?
Ken
scottb 08-16-2006 10:21 AM
If you're going to re-epoxy it, I suggest JB Weld. That stuff is bulletproof!
Scott
911pcars 08-16-2006 10:22 AM
With the shift lever in fifth or reverse, the bent tab on the shift lever should fit flush against each carrier plate tab. Before welding or using epoxy, place reference marks on the lever parts so it goes back together correctly.
Sherwood
more info here
BR-549 08-17-2006 09:26 AM
Thanks Sherwood, for the help and for posting the diagram. I'll take a shot at it this weekend.
Ken
