davis911s
Guest
Posts: n/a
Hard starting 77 s
My 77 911s is sometimes hard to start when hot and cold too. I ussually have to pump the gas or floor the gas pedal when starting it ( I know this is wrong with fuel injection) but it works, Wha t could be causing this??????PLEASE HELP.
Shawn
Old 03-24-2000, 04:50 PM
nhromyak@yahoo.com
Guest
Posts: n/a
I would suspect it to be either hydro-lock and/or a leaking fuel system. It sounds like the fuel pressure is able to back-feed through the fuel-pump. Something about a check-valve at the pump comes to mind. I think this check-valve got moved around for differing years.
Also, the CI$ head-unit could be leaking (hope not).
Good Luck
I suspect Warren will have better insight.
Nick
Old 03-24-2000, 05:27 PM
davis911s
Guest
Posts: n/a
How can I check if it the CIS head unit? Is it possible to check the Check valve? Does anyone kno where it is on a 77 911s with 2.7 CIS?
Old 03-24-2000, 05:43 PM
Rufblackbird
Guest
Posts: n/a
Davis,
I've had lots and lots of trouble before trying to start my '76 911S 2.7. The check valve you're looking for would be in the fuel pump. How you check it I don't really know. What also could cause this problem is a defective fuel accumulator. It helps hold the pressure in the system for easier starting/restarting. You might want to check this also.
Jeff
1976 911S
Old 03-28-2000, 03:29 AM
placerville
Guest
Posts: n/a
I’ve got exactly the same problem with my ‘74! If I turn the key to the ON position and let the fuel pump run for about 15 seconds before I try to start it - it starts right up. No visible fuel leaks and I replaced the accumulator. It’s got to have something to do with the check valve. It sounds like this valve is “inside” the fuel pump – is this a serviceable item or am I looking at replacing the pump?
Mike
Old 03-28-2000, 12:23 PM
