degreeoff1's Avatar
Weber throttle shafts
How do youo know if they are loose?
Are we talking about a side to side play or up and down...gripping from the linkage point?
Josh
1972 914-6 in the works.....
2003 Ford E-250 "work horse"
2004 Yamaha V-star Classic 1100 "early mid life crisis"
2005 Scion XB "Gas sipping"
1978 Siedelmann S25 "Ataraxia"
Old 08-17-2006, 12:30 PM
A Quiet Boom's Avatar
Wiggle test at first, then with the engine running spray carb cleaner on the loosest ones. If the engine speed changes much the shafts need to be rebushed. I'm fighting this on my Zeniths, a bent crossbar ovaled on hole for one of the shafts and the car stumbles at very light throttle. If I put heavy grease around the hole it will drive fine for 10-20 miles until the engine vacuum sucks in all the grease. I'm building a fixture so I can line bore a set of bodies I have and install teflon bushings. Technically they are plain bearings but lay people call them bushings. I asked the experts on a machining forum and the concensus was that teflon would be the best solution here.
Email me about 911 exhaust stud repair tools, rsr911@neo.rr.com
1966 912 converted to 3.0 and IROC body SOLD unfortunately
1986 Ford F350 Crew Cab 7.3 IDI diesel, Banks Sidewinder turbo, ZF5 5spd, 4WD Dana 60 king pin front, DRW, pintle hook and receiver hitch, all steel flat bed with gooseneck hidden hitch. Awesome towing capacity!
Old 08-17-2006, 01:50 PM
