-   -   SC and turbo A/C compressor : compatible ? (http://forums.pelicanparts.com/porsche-911-technical-forum/299472-sc-turbo-c-compressor-compatible.html)
Gengis 08-18-2006 03:02 PM
Hello,
I am about to buy a york 'sc' compressor for my 911 Turbo (1979).
The original compressor :
http://img216.imageshack.us/img216/8611/yorkyr0.th.jpg
The SC compressor :
http://img144.imageshack.us/img144/5...rksczx6.th.gif
see also this picture
http://img509.imageshack.us/img509/6...hotovk1.th.jpg
The mounting set :
http://img69.imageshack.us/img69/892...tingei2.th.gif
The 2 compressor plates (part #16 on the last schema) seem to be the same but the references are different. Do you know if the turbo's compressor plate can accept a 'sc' compressor ?
Thanks,
Gengis.
scottb 08-19-2006 08:24 AM
The York compressors are notoriously bad. Will a Nippondenso fit that engine with an adapter plate?
ruf-porsche 08-19-2006 08:53 AM
I brought a Seiki Seiko compressor with bracket from a 930 owner on this forum. The bracket is similar to the York bracket but with the adapter plates for a rotary compressor.
Nope you will need to get the bracket for a nippondenso.
See my thread on various compressor for the 911
http://forums.pelicanparts.com/showthread.php?s=&threadid=290187&highlight=seiki+ seiko
Gengis 08-19-2006 02:05 PM
Thanks for your post, I already have the completing mounting set for the nippodenso (and I also have a brand new nippodenso) but the fixation on the exhaust support is not the same :( IMHO, making holes in the exhaust support just for A/C purpose is not a good solution.
I do not expect miracle from the york compressor but would be happy to have 25°C in the car when it is 35° outside.
But I still do not know if the york 'sc' compressor is compatible with the 930 mounting plate.
ruf-porsche 08-19-2006 02:56 PM
Just looking at the bracket that I got for my seiki seiko compressor that came out of a 930 I would say that the brackets are similar. The only difference is that there is no belt tensioning adjustement screw.
Gengis 08-19-2006 04:24 PM
Ok, Thanks 'ruf-porsche'. I made a layout from my compressor plate, scanned it and sent it to the seller and asked him to print it and compare with the compressor so he can see if the holes on the plate come in face of the screw holes of the compressor.
I keep you informed ;)
Gengis 08-24-2006 02:17 AM
Hello guys,
I managed to fix the nippondenso compressor on the original mounting set (initially designed for the york). I only had to remove the York compressor plate and replace it by the nippondenso compressor plate. The later can easily be fix on the original bracket (see item #13 in the last schema of my first post).
