-   -   88 no start problem -- looking for the easy way out (http://forums.pelicanparts.com/porsche-911-technical-forum/299586-88-no-start-problem-looking-easy-way-out.html)
tubwreck 08-19-2006 10:59 AM
Stock '88. About one in 20-30 times trying to start it, this is what happens:
- Key on (oil light on, alt light NOT on)
- Key to 'start' and you get...
whirring fuel pump
big click/clunk from under the back seat
Sometimes, if you try 15 or 20 times, it starts. Sometimes if you are lucky, put it in 3rd gear with the clutch up and nudge it while holding the key in 'start'.
Should I just bite the bullet and by a digital VOM and run the full diagnostic procedure, or is there a 99% chance that it is the starter motor?
Any suggestions appreciated!
Wil Ferch 08-19-2006 11:08 AM
You are *not* getting "whirring " of a fuel pump.... it's something else.
Unlike ( maybe) CIS cars...DME cars have a "start permissive" in the circuitry that won't allow the fuel pump to run unless it is "sensed" that the motor is actually spinning...
A safety feature for when the car ends up on its head and you don't "feed a fire".....
- Wil
tubwreck 08-19-2006 11:26 AM
I'm pretty sure that the fuel pump runs when the *starter* circuit is engaged -- otherwise there would be no fuel provided to the engine during cranking.
The other borderline odd thing is the Alternator light. Sometimes on, sometimes off.
ruf-porsche 08-19-2006 11:26 AM
Is the engine turning over when you try to start it or just a whirling sound. Could be a bad solenoid on the starter.
DW SD 08-19-2006 11:36 AM
The fuel pump doesn't run unless it sees that the crank is turning via the crank position sensor. The computer actually gives the pump power via DME relay stage II.
When you say it starts, does it run or is it merely cranking?
I would guess the clunk from under the seat is the starter relay. Are you sure the battery is charged? What happens to the voltage at the battery when you turn the key to crank (does it drop WAY down?)
Another test would be to check voltage at the starter when you turn the key to start.
I'd check to make sure you have a good chassis ground. That could effect the alternator light (if I remember the alternator idiot circuit properly).
Doug
Wil Ferch 08-19-2006 11:40 AM
quote..." I'm pretty sure that the fuel pump runs when the *starter* circuit is engaged -- otherwise there would be no fuel provided to the engine during cranking. ..."
Why do people ask questions and then argue against the facts ....??
yeah...maybe when the "starter" circuit is engaged AND it is sensed that there are actually RPM's during the start attempt !!! ......
no rpm's...no fuel pump running !!!
- Wil:eek:
ruf-porsche 08-20-2006 07:37 AM
Originally posted by Wil Ferch
quote Why do people ask questions and then argue against the facts ....??
- Wil:eek:
Because they like to argue?
ischmitz 08-20-2006 09:06 AM
A voltmeter would certainly help here ;) Check the battery voltage, check if the alternator is charging, check if there is a voltage drop somewhere (ground strap, battery connectors, connectors at the starter, etc)
Without that it's just wild guessing.....
rick-l 08-20-2006 10:26 AM
If you look at FR Wilks schematics Pin 4, which comes from the starter solenoid, is ORed with the DME command that drives the DME relay pin 20.
That might be the fuel pump
2.7RACER 08-20-2006 10:30 AM
Ed,
You can buy a decent meter today for less than $20. Harbor Freight for less than $5.
Unless you are clairvoyant, you'll need the meter.
rick-l 08-21-2006 09:12 AM
Not necessarily, although nice to have (but know how to use it also).
You know the ignition switch works, the Fuel Pump Runs.
That big clunk is the solenoid trying to pull in.
This does not sound electrical in nature to me. Time to get dirty and look at the starter/solenoid .
ruf-porsche 08-21-2006 10:15 AM
I guess you miss my previous response.
rick-l 08-21-2006 10:58 AM
I understood the symptoms to be a loud clunk and the engine not turning over. (0 RPM)
To me this would mean the contact in the solenoid that energizes the starter winding is not being made either because the contact is bad or the contact is not closing due to the gear hung up and not engaging the ring gear allowing the contacts to close.
Either way starter removal / exam is required unless you just want to shotgun the whole assembly, which may not work either.
DonMo 08-21-2006 03:56 PM
Testing
A volt meter and the diagnostic page out of the Bentlleys for the Motronic should help you. You disconnect the connector to the ECU and check pins and find out a bunch of useful info. Meter on VAC and engage starter will tell you if you are getting reference and speed sensor readings. You can check grounds, you can pin out the connector and hear your fuel injectors engage, you can pin out connectors and make the fuel pump run. Here is the pin layout, let me know if you need the diagnostic pages.
http://forums.pelicanparts.com/uploa...1156200891.jpg
Lorenfb 08-21-2006 05:32 PM
"yeah...maybe when the "starter" circuit is engaged AND it is sensed that there are actually RPM's during the start attempt !!! ......"
No, only needs to "see" the #50, i.e. the starter signal @ pin 4.
rick-l 08-22-2006 09:18 AM
Back to the original topic
Ed
Any luck with your starter? No loose cables (the big one)? Does moving the car in gear allow it to function? Can you jack it up and beat on it when it doesn't work?
