Differance between 71 and 73 drive shafts
Are they interchangable, they both have the 2 dowel pins, with 4 allen bolts-TIA-Bill
Old 09-21-2006, 08:09 AM
axles or as I call them, half shafts. the output flanges from the transmission appear to be the same on both the 901 and the 915-
Old 09-21-2006, 08:12 AM
I believe the early 915 gearboxes use the same 4-bolt CV joints.
Sherwood
Old 09-21-2006, 11:01 AM
304065's Avatar
915's to mid-74 use four 10mm bolts and a pair of roll pins.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 09-21-2006, 12:11 PM
thanks-bill
Old 09-21-2006, 01:18 PM
I believe the axles on the early 915 transmission are slightly shorter than those for the 901 gearboxes. From memory I think they were about 5mm difference. Given the CV joint's allowed excursion, I didn't think it would be a problem. I went and used a set of 69 axles on my 72, and they seem to fit and drive ok. Paul.
Old 09-21-2006, 05:03 PM
thats good to know, as im using shafts from a 71 on a 915...thanks-bill
Old 09-21-2006, 06:43 PM
