German Blood
Positive Battery post
Anyone know where to find a battery post extension for the positive side of the battery for an '86 911? I always fight with getting the damn thing tight because I can get a wrench in the recessed area around the post. The positive lead going to the car is cut to length and is stiffer than some of the drinks I had in college and cannot be moved.
Any ideas?
'86 3.5L TP Coupe |
I find it easier to first move the battery away from the wall as much as I can in order to have enough space for the wrench. This way I can connect then tighten the positive side. Then I secure the battery on its base with the hold-down fixture, and only then, I connect the ground lead to negative pole.
I do the opposite whenever I need to disconnect the positive side and/or remove/replace the battery.
Gilles RoW 88 Carrera coupé |
i have a stubby 13mm ratchet wrench .. and its fine.
https://www.amazon.ca/uxcell-Stubby-Ratcheting-Combination-Wrench/dp/B09PFXJJVP?source=ps-sl-shoppingads-lpcontext&ref_=fplfs&smid=A30WUG2ZDGM0XM&th=1
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
Get a reversed style battery. I think those are marked R, like Group 34R. That puts the pos post near the fuel tank, but on the same side as it is currently - closer to the firewall than the front of the car.
When I replaced my SC battery just last week - I had the same issue as you - which is "normal".
I took an inexpensive (cheap!) spare open end wrench and ground down the beefy edges on both sides. I also cut off the other end of the wrench to make it shorter. This modification gives a LOT more room to insert the wrench, get a good turn on the nut, extract the wrench and repeat. Edited to add the pictures. ![]()
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? Last edited by MBAtarga; 05-18-2024 at 12:20 PM.. |
German Blood
Good ideas! Thanks.
