Urgent help 87 911 wont start after vacation
Any suggestions welcome
I drove into my garage 2 1/2 weeks ago
try to get it out today
wont start
cranks fine
Ive got gas
any thoughts
URGENT
thanks
Mike
Old 08-13-2006, 10:25 AM
try jumping it.
your batt may be strong enough to turn the starter, but not strong enough to drive the FI & ignition electronics.
Old 08-13-2006, 10:31 AM
I'll try that thanks
Mike
Old 08-13-2006, 10:34 AM
DME relay
69 911 2.3Ez
85 928S
Old 08-13-2006, 10:42 AM
Hi tried jumping it NO difference
just turns over & over
had a hint of firing about 30 mis ago ??
please help
Mike
Old 08-13-2006, 10:51 AM
put a new dme relay in about 2 months ago
I tried swithing it out with the old one but no difference ??
Mike
Old 08-13-2006, 10:52 AM
MXMARK's Avatar
No Idea. Fuel line leaking under front. Thanks Mark
1985 Targa Carrera
1972 914 2.5L four, side shift
1987 944
2005 Husqvarna CR125
1980 YZ125G
Old 08-13-2006, 10:53 AM
how can I check the fuel pump ?
is there a fuse I should check ?
Mike
Old 08-13-2006, 10:54 AM
MXMARK's Avatar
Swap another relay maybe? check this post for relay picture
Factory alarm 85 carrera
1985 Targa Carrera
1987 944
1980 YZ125G
Old 08-13-2006, 11:00 AM
Hi
took a plug lead off and put a new plug in against the head no spark
I have interchanged 2 dme relays with no success the one is only 2 months old isnt that a bit quick to fail ?
any help !!
Mike
Old 08-13-2006, 11:09 AM
MXMARK's Avatar
I had a cap break on me from ? I dove it then let it sit for 2 weeks went to start it and nothing. The cap broke.
1985 Targa Carrera
1987 944
1980 YZ125G
Old 08-13-2006, 11:15 AM
which cap are you talking about ?
Old 08-13-2006, 11:23 AM
Sultan of Sawzall
rouxroux's Avatar
distributor cap...Maybe if you have a hairline crack, enough moisture has seeped in (sort of the same effect as a car wash)...Might check coil as well. Best of luck.
Gruppe B #319
'66 Monza coupe 110/PG(white)
'95 993 cabriolet (wife's)
Old 08-13-2006, 11:29 AM
MXMARK's Avatar
Dist cap
1985 Targa Carrera
1987 944
1980 YZ125G
Old 08-13-2006, 11:33 AM
Hi took of dist cap all looks ok
now I cant get it back on is there a special way ?
I dont see any alignment marks or anything ?
doesnt this affect the timing ?
Getting hot and pd off now please keep helping
Mike
Old 08-13-2006, 11:45 AM
Sultan of Sawzall
rouxroux's Avatar
The cap screws push DOWN, then turn, release...the spring tension holds it on. You might have a crack that you can't see. Was the inside of the cap dry? How did the contacts look (rotor contact as well)? Were they shiny?
Gruppe B #319
Old 08-13-2006, 11:49 AM
ok got it back on it was dry inside contacts looked a little crroded so i cleaned them up still no spark
is there a fuse or somthing tbefore the DME valve ?
running out of ideas
rgds
Mike
Old 08-13-2006, 12:22 PM
what check is ther for the coil ? and where is it ?
mike
Old 08-13-2006, 12:23 PM
DW SD's Avatar
Can you hear your DME relay clicking on? Stage I should come on in the relay with the ignition key to "on" position.
Stage II on the DME relay powers the fuel pump. The computer needs to see the crank position moving before it lights the fuel pump. Is your fuel pump coming on or getting power during cranking - use a test light?
I'd make sure you get power at the DME relay (that turns on the computer). From there, the computer will turn on the fuel pump, injectors and time spark. I think if you have no spark only, it could be bad grounds, bad coil, no rotor in the distributor, OR??
Doug
1971 RSR - interpretation
Old 08-13-2006, 02:05 PM
Doug
thanks for the reply
I have given up for the day
I turned the key and it started as usual for abot 10 seconds then died no further luck
so I think it is something simple
how do i check power to the DME ?
I'll go and listen to the dme
thanks
Mike
Old 08-13-2006, 02:33 PM
