Has my outer CV joint gone??
Dear All,
Further to my post here: http://www.porscheclubgbforum.com/tm.asp?m=197831&mpage=1&key=joint𱶃 The noise has returned. I've not used the car much this year for various reasons. Anyway, she was MNOT'd last week and used it one day. Then yesterday I went to the Tatton Sports and Classic car show aand half way there, about 6 miles, the noise came back. Funny though, when I drove on the grass it didn't make the noise but on rough roads it sounded dreadfull, clicking and creeking (also more pronounced when changing direction. Anyway, I got it home and took off the rear OS wheel. When turning it, it can be fine but then stops. With more pressure it moves past this with a click. THis happens most of the time. The noise comes from within the hub. The thing is, there's spacers on the car and I couldn't remove them so didn't take the hub apart last night as I need a deep 19mm socket to remove the spacers. There doesn't seem to be any play in the wheel. Both times it has occurred has been after the car has stood. Does this sound like a CV joint? It's definitely coming from the hub so I think it must be CV joint or wheel bearing. Can't quite see the CV boot sso can't tell if it's split. Anyway, if anyone has had one go and could give me some pointers that would be great. Hope to have the hub apart mid week. I remember CV joints on my Mini sounding like this when they had gone! Cheers Kris |
Symptons as outlined sound more like a CV than a bearing. What kind of spacer are you referring to? Have a similar problem in my 914 and the symptons are similar - niosier when going over bumps and turning. May try repacking it - but that will only delay the inevitable.
The spacers are for the rear wheels. CAr is turbo bodied with larger wheels on it. Are the outer CV joints the same on turbo bodied cars?? I know they run turbo running gear........cheers
Kris |
| All times are GMT -8. The time now is 11:20 PM. |
