Well next month I do my first DE and there is a requirement for my car to have numbers on the exterior. They have to be minimum of 6 inch on the doors and 4 inch on the rear. I'm thinking magnetic but where do you buy these? The # 12 is what I'm going to use. I didn't see any from our host.
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
You might try calling Pelican to see if they can get them even if they aren't on the site.
Also,looks like Rennline has them: http://rennline.com/product.php/sid/5/aid/28/auto/Porsche/prodid/25 Additionally, try http://www.nbdgraphics.com/ I think it's a Pelicanite who does No Bad Days Graphics :-)
74 911 with '95 3.6l |
<insert witty title here>
Probably depends on your region, but UCR allows you to print them on your home printer and tape it inside the rear windows, so long as they meet the height requirements and it's black ink on white paper. They also allow electrical tape on your doors (won't hurt the paint) unless of course your car is black
![]() If you definitely need/want magnetic, look in the yellow pages for sign makers. They'll do them up for you. IIRC mine were about $30 for a pair. But you'll need to tape them to your car - these are meant for pizza delivery guys, not a Porsche whipping around the track at 100 miles an hour! Even some well-equipped print/copy shops can do them.
Current: 1987 911 cabrio Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster |
Most sign company can make you a set.
abit off center
I cut out my own from a white magnet sheet
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
MBruns for President
Good info here
Poor Man's DE/TT Car Numbers
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
In the automotive section at walmart they sell window chalk you can use for this. They also have a clear spray for the front end to help minimize rock chips. Painters tape works well for that also. If you really need vinyl, check your local vinyl sign shops and they can make them for you in whatever size, font, and color you could want.
Brian Starr Alabama Region PCA 1983 911SC/Rebodied as 993 w 3.6 1995 911 C2 (Sold) |
UFLYICU
Try Office Depot for the giant magnetic door sign set. Print your own numbers on sticky paper and stick them to the magnetic sheet. I cut the magnetic sheets into ovals, and printed black numbers.
_______________________ Racer Rix Spec911 #5 prc-racing.com |
Better in Person
or get the sheet stuff like rick mentions and go to a motorcycle shop, they have big stick on #'s pretty cheap. do a search for internet magnetic sheeting, cheapest way to go. the sign companies will jab you for the sheeting
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
Zink Racer
racers tape
Jerry 983 911 SC/Carrera Franken car, 1974 914 Bumblebee, 1970 914-4 |
Southern Class & Sass
Buy a roll of low or medium stick shelf paper. Use your PC to print numbers as templates. All you need then is a razor and a kitchen cutting board.
It works out to something like 50 numbers for four dollars.
Dixie Bradenton, FL 2013 Camaro ZL1 |
Solotime does nice work.
Also EuroPDR Be careful with magnetic. I have ovals with 8 inch numbers and they ruined my paint in the summer heat. The magnetic sheet gets so hot in the summer sun, it appears to have baked the clear coat on my doors. I was able to smooth it out a bit with some compound, but the damage is still visible from an angle. Static cling and reuseable low tack stick on vinyl are alternatives to magnetic.
George M '89 Carrera 3.2 '91 928GT '76 914 '18 Macan GTS |
I went to edecals.com
