Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 911 Technical Forum
Bill Sherwood
Guest
Posts: n/a
915 gearbox ratios.
After the ratio's for the 911's 915 type gearbox. Also, what torque/HP they can take stock - I have recently bought one and it's going behind in a V-8 sports car.
Regards,
Bill Sherwood.
Home page here - http://www.onthenet.com.au/~billzila
[This message has been edited by Bill Sherwood (edited 04-07-2000).]
Old 04-07-2000, 07:38 PM
Early_S_Man
Guest
Posts: n/a
The 915 was in production from 1972 through 1986, so there were several versions, with 3 different ring & pinion ratios available. If you knew the year of car it came out of it would help! Even if you don't, there is a 'series' number stamped on the bottom rib, and it will appear as 915/xx, and there is also a serial number, too, close by. As far as the hp and torque ratings go, I'll have to look that up in Paul Frere's book. But, with a cooler, pump, and spray squirters, the competition models were good for some big numbers! Get a copy of Bruce Anderson's 'Porsche 911 Performance Handbook' ... he has a chapter with plenty of pictures and ideas! You should visit PowerHaus II at URL: www.phii.net and take a look at their gear offerings!
Warren Hall
1973 911S Targa
Old 04-07-2000, 08:29 PM
Bill Sherwood
Guest
Posts: n/a
Thanks - I don't have ready access to the gearbox (I'm in a different state at the moment) so I can't check, so I'll have to either wait until I can get to it, or simply 'count the teeth'.
FWIW, I'll be needing a diff ratio of about 4.3:1, and it's going into a car that should have about 500hp/380ft-lbs, and weigh about 1500lbs, with driver.
Old 04-08-2000, 02:48 AM
RarlyL8
Guest
Posts: n/a
I wouldn't use the 915 if you're running an actual 500 HP. You can break them with a 200 HP 3.0L SC if you dump the clutch too many times (I have a friend who's done it twice while dragracing). You might consider a 930 4spd, although the gearing may need to be changed. The HP/torque specs you give hint at a high strung (turbo?) engine. If this is the case then takeoff shouldn't be the problem, but a 1-2 hard shift with all the power down might be. I'm an advicate of overkill. You know your driving habbits.
Old 04-08-2000, 05:52 AM
H2O911
Guest
Posts: n/a
V8 torque is a little different from the 6 cyl.
The V8 has 4 "pulses" per revolution instead of the 3 "pulses" that the 6 cyl has.
So from a technical stand point there is less time between crank pulses and, as a result, it is smoother. This "smoother" will let you increase the torque at the crank with less of a shock factor on the rest of your components. This could / might explain why these transmissions break with 6cyl's with less power.
With that said I have been told/read the following
1972-76 the 915 was good for 450ft/lbs (v8)For 1977-on the main shaft was strenghtend and it could now survive 600 ft/lbs (v8)
Your weak link will be your clutch set up. If you abuse it, it will go away quicky and smell bad.
Anyway, the 911sc is good for about 325 ft/lbs but the PP and the disc can be up graded to handle about 450 ft/lbs
I gave you the torque figures because that what seems to be important here
You also might want to get a taller R&P because you will be stirring the gears very quickly and this box is not renowned for it's lightning fast shifts from 1st-2nd.
Hope it helps
s
Old 04-08-2000, 07:38 AM
H2O911
Guest
Posts: n/a
thanks rarelyL8
I almost forgot the 930 box (turbo 4-speed)can handle about 700ft/lbs of V8 torque and the clutch will hold up too!
s
Old 04-08-2000, 07:47 AM
JP Noonan
Guest
Posts: n/a
Best way I've heard to find out the ratios tis to actually mesure them. Turn the CV flange and count how many times it turns the main shaft. Do it for every gear. Sound right to anybody?
Old 04-08-2000, 09:14 AM
Bill Sherwood
Guest
Posts: n/a
H2O911 - Thanks, but I need the 4.3:12 diff ratio to make the engine rev out to near max revs in 5th gear - ~290kph.
Since it's a pure racing car, I'll only be doing the 1 - 2 shift once, then using the rest of the gears as needed. In fact, I doubt if I'll be using 5th gear much, as there's not that many tracks here in Aus that have a long enough straight to get to 290kph!
FWIW, I'm traditionally pretty easy on the gearbox, eg, I've had a 10,000rpm 180hp Suzuki GTi 1300cc twin cam running through a Toyota K-50 Corolla early model gearbox with no problems. (New engine in now though, only has ~140hp due to new rules)
Old 04-08-2000, 05:35 PM
Bill Sherwood
Guest
Posts: n/a
FWIW, this is the 1300cc racing car -
... and this is the car that the V-8 & 915 gearbox are going into -
... and this is the engine - (pre mods)
Old 04-08-2000, 05:40 PM
RarlyL8
Guest
Posts: n/a
A 915 should do you under these conditions. There is a previous thread on gear ratios where Warren listed the gears and suppliers. What type of V8 is that?
Found it: 4/1/00 Till Kueger, Changing Gear Ratios.
[This message has been edited by RarlyL8 (edited 04-09-2000).]
Old 04-09-2000, 04:58 AM
Bill Sherwood
Guest
Posts: n/a
boo-boo post - ignore.
[This message has been edited by Bill Sherwood (edited 04-09-2000).]
Old 04-09-2000, 08:21 AM
Bill Sherwood
Guest
Posts: n/a
Thanks - I'll have a look for the ratios.
The engine is a Toyota Lexus 1UZFE all alloy 4 litre quad cam V-8. With not a lot of mods, I'm expecting a good 500hp from it.
Bloody strong - they have a six bolt bottom end - stock!
Old 04-09-2000, 08:22 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
