rnln's Avatar
Anyone know how to take the knee pad off, right below the glove box ?
Anyone know how to take the knee pad off, right below the glove box?
Fat butt 911, 1987
Old 08-23-2006, 06:20 PM
Reach behing the dash and remove the nuts holding it on.
JR
"Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." *** Aristotle
Old 08-23-2006, 06:21 PM
rnln's Avatar
I found a screw near the door, not under dash. That's all I could find. When you say behind the dash, where exactly it is?
Fat butt 911, 1987
Old 08-23-2006, 06:37 PM
another round please
strupgolf's Avatar
It's kind of hard to find the nuts, but there are about 3 or 4. I hope you are a contorshinoist,??? In the 911, I've never had such difficult times getting to things under the dash. Also, find the screw that holds the air vent on, its on the dash on the side. Take that off, pull the vent, and I think one of the nuts is under that. Cheers
Getting old is not for wimps.
Old 08-23-2006, 06:39 PM
rnln's Avatar
Thanks, will work on it more.
Fat butt 911, 1987
Old 08-23-2006, 07:17 PM
Reach underneath the pad until you feel a metal lip behind it. Run your finger inside this metal lip from side to side until you feel a stud with a nut on it. That's what you want to unscrew. You may wish to look under the dash with a flashlight and a mirror to find them.
If you have the right kind of screwdriver to remove the glovebox without having to remove the glovebox door first, you can access the nuts easier.
JR
Old 08-24-2006, 04:56 AM
rnln's Avatar
Thanks javadog. Sound like it's easy. I know it's not.
Thanks.
Fat butt 911, 1987
Old 08-26-2006, 01:13 AM
Not Quite Banned
Thomas Owen's Avatar
I seem to remember there were only 2 nuts, one near the radio and the other over by the glove box.
Good luck -
Thomas Owen
1972 911T
1972 911S
Old 08-26-2006, 03:29 AM
Jim Smolka's Avatar
An 8mm socket, extension and 1/4" ratchet is needed.
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 08-26-2006, 04:36 AM
thaxtela's Avatar
Just removed mine last week. Had to remove the side vent to access one screw. Found it easier if I pulled the radio out to get the second one. My radio is after-market so removal was quick and easy.
1986 911 Factory Turbo Look Targa 3.2 litre
Old 08-26-2006, 04:33 PM
