Banned
Posche SC guage problem?removal??
When I drive, my speedometer does not work until I reach 30 mph, then the needle moves up to 30 mph and up from there as i speed up. The RPM guage also acts up sometimes. Any suggestions towards what to do, bad connection? and how to remove them??? Do I spin then off and out? Thanks
The guages simply pull out from the dash. There is a rubber gasket that hold them in place. You can also push them out through the front trunk.
Check your connections once you get them out. If you have afew miles on the car, it's probably time for a rebuild. Hollywood Speedometer is a poular choice to repair the guages.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
