Danny_Ocean's Avatar
Oil change "kit"?
Is there an oil change "kit"? Instead of searching through the catalog looking for everything piece-by-piece, I'm wondering if there is a part # for a kit containing everything (gaskets, washers, screen, etc.)...
Old 08-27-2006, 02:42 PM
Crusty Conservative
silverc4s's Avatar
There should be a "valve adjustment kit". Oil change is basically oil & filter if you are not doing the valves.
Bill
69 911 T Targa, 2.4E w/carbs (1985-2001)
70 911 S Coupe, 2nd owner (1989- 2015)
73 911 T Targa, 3.2 Motronic (2001- )
Old 08-27-2006, 02:52 PM
I've got some drips around the bottom sump plate, so I figure this would be a good time to change everything (crush washer, sump gaskets...?).
Old 08-27-2006, 03:02 PM
LakeCleElum's Avatar
I looked for one a few months and "no luck".....Bought the all crush washers, sump gasets, etc. invidividually.....
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 08-27-2006, 03:05 PM
Crusty Conservative
silverc4s's Avatar
I think the VA kit comes with a crush washer and two sump gaskets, if I recall correctly. I seem to have some laying about like that.
Bill
Old 08-27-2006, 03:06 PM
Thanks. I remember purchasing such kits back in my "VW days".
Old 08-27-2006, 03:07 PM
Crusty Conservative
silverc4s's Avatar
Everything you want is listed in the PP catalog under Valve Cover Gaskets.. Right here on line.
Bill
Old 08-27-2006, 03:10 PM
Yeah, that's where I was looking. Just a bit tedious. Was hoping for everything in a nice big shrink-wrapped pile!
Old 08-27-2006, 03:12 PM
Crusty Conservative
silverc4s's Avatar
Upon reflection, I would say that in the days prior to the 3.2 L engine, all cars used the same gaskets and a "kit" made sense. Nowadays there are many times when the sump gaskets are not called for, as the sump plate is gone and forgotten on the newer cases. So, seperate items are the sensible packaging option.
Bill
Old 08-27-2006, 03:23 PM
