Order Online or Call:
888-280-7799
HACKER SAFE certified sites prevent over 99.9% of hacker crime.
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
Click Here To Add Your Car to Our Owner's Photo Gallery!!!
Chat with other Users in the Chat Room NOW!!!
banner
The Pelican Parts Forums salutes the memory of Warren Hall (Early S Man), 1950 - 2008.  You will be missed by all... [Click for more details]
ErVikingo's Avatar
What's the story with the shifter?
For sale: VERY fast 2 Liter Vintage Race Cars; BMW M Coupe Race car + photos and videos: www.alteregoracing.com
Old 08-27-2006, 07:58 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #21 (permalink)
KCPSG's Avatar
WEVO short shift.
Phil
2005 GT3 Milltek Exhaust/ECU reflashed/OEM Short shift
1988 911 coupe (GP white) Turbocharged
1998 BMW 328i
Old 08-27-2006, 08:00 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #22 (permalink)
are you still grinning?????????
Ben 77 911s 3.2ss/EFI/ turbocharged
Ask about our new M&K motorsports exhaust ben@mkexhaust.com for details.
Old 08-27-2006, 09:28 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #23 (permalink)
Ohr zum Ohr
Old 08-27-2006, 09:59 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #24 (permalink)
Doesn't want/need a 3.6L
Carrera3.5L's Avatar
Jerry,
Congratulations on a succesful turbo conversion. Your preliminary times do seem to indicate a very fast car..
In 2004, Steve Wong and I did some similar logging while mapping chips for me and to try and get some comparisons with a 3.2L motor and my than new 3.5L twin-plug conversion.
Steve's '84 3.2L (while stock internally) has all of the typical "bolt-on" mods for a 3.2L, guestimating power to be somewhere in the 235-245 crank horsepower range. My '88 dyno's in the low/mid 240's on a dynojet, so add in your desired driveline loss for a crank horsepower number.
On a straight, level road and in 3rd gear from 2,100 rpm to the 6,840 rpm cut-out used for both cars, Steve's car (with him solo) did it in 15.5 seconds and mine (with him in the passenger seat adding some additional weight in an already heavier car) did it in 12.78 seconds.
Things have changed though since those tests, his car is in a slightly different configuration and my car's been lightened 200 lbs. since than but if you can log a similar test to ours it will give those interested some idea how much faster a turbocharged 3.2L can be over normally aspirated versions, albeit not taking into account car weight differences.
It would be nice to also get some data on completely stock 3.2L's (which Steve probably has) just to see how dramatic a difference it really is...
Ralph
1988 Carrera w/ 3.5L Twin-Plug
2008 Cayman S (coming soon)
Old 08-27-2006, 12:33 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #25 (permalink)
I have logs of stock 24 pin and 28pin, also autoauthority and steves 24 pin. We were always around 15 -16 seconds from 2000-6500. It's good to know other people saw the same numbers.
Right now I'm using proto's stage one, and the curve is messy. Steve didn't have one to sell at the time ( ithink he does now though)
I used 6000 as the high mark because I really dont want to go all the way up with the turbo, so i was measuring from 2500 to 6000.
8.66 seconds in the turbo and 13.58 in NA with Steve's chip
It's a tiny bit fast
I'll look at another stock '88 log and see what it shows.
thanks for the comments
Old 08-27-2006, 12:45 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #26 (permalink)
I have one of the logs that Steve ran for me, but I can't change the parameters to show what the time would have been for 2,500-6,000 rpm.
Looking at the graph (and if I'm reading it correctly), I would "guess" that 2,500 rpm to 6,000 rpm for the 3.5L in my car when run a couple of years ago would be somewhere around 9.0 - 9.5 seconds???
You aren't even done tuning it yet, I'd like to see what the numbers are on a dynojet versus stock (you did do a baseline, right?)...
If only we didn't have stringent emissions laws in California...
Ralph
Old 08-27-2006, 01:46 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #27 (permalink)
great info jerry and ralph. Very real world comparisons
Old 08-27-2006, 02:30 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #28 (permalink)
WydRyd's Avatar
oil drain...
FYI, I'm planning to use one of these to drain the oil from a GT35R BB turbo into the chain housing cover via some purosil hose:
The new Garrett's don't need that much oil anyway and the suction pressure from the engine should scavenge the oil back into the motor reliably
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 08-27-2006, 04:57 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #29 (permalink)
that's what we figured merv,
ralph, I'm envious of your purple line.
here's a shot of today's compared with a couple months ago, you can play with the time stamps. These two show almost 5.5 seconds. also notice I stamped the turbo a few RPM higher. I'm getting interference on the pick up clamp and I've heard it's harder to use on magnecor wires. I'll wire it up better soon.
Old 08-27-2006, 05:07 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #30 (permalink)
jerry So have you dialed it in a bit better? Is it running to your expectations?? Nice and cool up here tonight I blew the silicon boot right off the tubing(did not tighten it properly after removing it to put in that damn restrictor
Old 08-27-2006, 07:22 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #31 (permalink)
WydRyd's Avatar
Use these Constant Torque clamps! They're awesome!
http://www.breezeclamps.com/ct.htm
Merv
'89 911 Turbo Cab
Old 08-27-2006, 11:16 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #32 (permalink)
Join us in Monterey for the Pelican Wine Tour & Canyon Run!  Click Here!
I will check them out
Old 08-28-2006, 04:03 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #33 (permalink)
Crotchety Old Bastard
RarlyL8's Avatar
The difference betweena N/A and a turbocharged engine a phenominal.
My data point:
Modded SC engine - 14.2 sec @ 92 mph in the 1/4 mile.
Modded 930 engine - 8.5 sec @ 90 mph in the 1/8 mile.
Same car, same tranny.
60mph - 100mph times were reduced from 10 sec to 4 sec.
Brian B.
RarlyL8 Motorsports - 930 Turbos and Exhaust Systems
ph: (256)698-4992 Email: Brian@RarlyL8.com
'78 911SC Widebody, mild 930 engine, 915 Tranny, K27, RL8 GT3 Muffler. 315whp @ 0.7bar, 8.5sec @ 90mph 1/8
Old 08-28-2006, 09:56 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #34 (permalink)
My data point:
Wow That just verifies the feeling one gets when driving one. I still smile when I run through the gears. It can get scary quick. I can't imagine some of these cars with 500 plus hp
Old 08-28-2006, 10:07 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #35 (permalink)
onefstm's Avatar
Send a message via AIM to onefstm Send a message via Yahoo to onefstm
Jerry,
Is the motor stock in your 87? Have you counted the number of fins on your cylinders to verify which P&C's you have in the 3.2?
95 Red 993 (Supercharged)
06 M5
Old 08-28-2006, 10:58 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #36 (permalink)
Originally posted by onefstm
Jerry,
your getting the boost bug arn't you It caught me the same way and I just got the will power to say NO.
Old 08-28-2006, 12:08 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #37 (permalink)
Jerry,
Great Point!
550hp 3.3 turbo converted to RSR wide body time attack monster
[url]www.amstuned.com[/url www.turbowax.com
www. motomotions.com www.amoremioil.com
  Recommend this thread for the PelicanWiki    Reply With Quote #38 (permalink)
http://videos.streetfire.net/search/ams/1/ee1f18e9-4f5c-4c90-bd91-07755bf25c4f.htm
Old 08-28-2006, 12:12 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #39 (permalink)
KCPSG's Avatar
Just got done driving Jerry's car...
All I can say is WOW that is freaking fast, especially 2nd and 3rd. that thing gets to red quick...over a 100 mph very quick. I cannot wait til I get mine installed. If Jerry aint smiling..I sure am.
Thanks Jer !!!
Phil
1998 BMW 328i
Old 08-28-2006, 12:56 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #40 (permalink)
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.1
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
Copyright 2009 Pelican Parts - Posts may be archived for display on the Pelican Parts Website
One of the largest message boards on the web !
