Engine compartment light, where?
Where do you install the engine compartment light?
Can somebody post a picture of this light installed? Also, the hot wire is always hot or should be switched? In case of switched, in what circuit (marker lights?) should I connect it? Thanks youhttp://forums.pelicanparts.com/uploa...1156641157.jpg http://forums.pelicanparts.com/uploa...1156641382.jpg |
Hi!
Maybe this will help. Can't help you with the wiring. http://forums.pelicanparts.com/uploa...1156644494.jpg SmileWavy Dave |
Slodave,
Thanks for the picture. Probably if you can answer these questions I can figure out how it is connected. The light can be turned on just by opening the chrome window when: 1.- Markers light on 2.- Nothing on Thanks again. |
The light in my car has not worked for a few years. I don't remember if it was switched or not. My car is also not with me at the moment, so I can't even test the socket for you. Sorry.
Dave |
Dave,
Thanks. Hope somebody will have an asnwer for me. |
light
Headlights have to be on!
47silver,
thanks, but that is not what I was asking. I know how to connect a light. This particular light fixture has a switch in the assembly, when you open the chrome part the light turns on. What I need to know is, if the light fixture is connected to an always live circuit or if it is connected to a switched marker light circuit. |
| All times are GMT -8. The time now is 12:12 PM. |
