way
Guest
Posts: n/a
are all 77 2.7's equipped with dilavar studs?
i have a 77 2.7 with 139k miles....how much longer will this thing go is of course a matter of the engine mods...it is the original with 11 blade, carrera tensioners, 49 state exhause (no heat chambers or whatever you call them)...it has all the paperwork from the previous owner....
i have heard some people say that all 2.7;s in 1977 had bottom dilavar and some say that only 1977 1/2 models and later had it...what is the truth here? thanks
Old 04-18-2000, 09:45 PM
mackgoo
Guest
Posts: n/a
I beleive that 771/2 is correct. I'll check the 911 hand book tonight.
Bruce
Old 04-19-2000, 08:46 AM
mackgoo
Guest
Posts: n/a
I just looked in the 911 handbook, all they say is "late" 77 911's got the bottom row of dilavar.
Bruce
Old 04-19-2000, 01:52 PM
Early_S_Man
Guest
Posts: n/a
Many of the 2.7 engines, '74 to '77, were retrofitted with Dilivar studs by dealers at the first sign of trouble, PCNA probably has records, but whether you could do a search or get an answer on your car is another matter.
Warren Hall
1973 911S Targa
Old 04-19-2000, 02:42 PM
Eddie Willers
Guest
Posts: n/a
Except these days, Dilivar studs are no longer the hot tip, because of corrosion problems! Even the factory stopped using them.
[This message has been edited by Eddie Willers (edited 04-19-2000).]
Old 04-19-2000, 03:55 PM
