PhatA55's Avatar
Desparately seeking ignition
Today I replaced the BOV gaskets that had deteriorated on my 1979 930 following the instructions in this post: Changing 930 dump-gaskets, pictures galore While I had everything apart I noticed that the larger hose on the back of AAV was split. I replaced both hoses and reassembled everything. I started the car and it fired right up but was idling very low, sometimes shutting off. I pulled the hose from the distributer advance and the idle picked up to about where it was before. I loosened the distributer just enough to move it so I could adjust the timing. I spun the dizzy a little and the engine didn't like it so I moved it back. Now I can't get it to fire at all. My pumps are running but I'm not getting fire. I made sure all of the wires were seated properly. The cap and rotor are about 2 months old so they aren't the problem. Any ideas what I might have done?
--Mark--
1979 RoW 930
1999 BMW Z3
Originally posted by randywebb
It is the people who have some kind of psychological problem and use the car (or some hierarchy they set up involving the cars) to try to elevate their personal sense of self-worth that irks me. I feel sorry for them of course, but they are difficult to put up with.
Old 08-27-2006, 11:25 AM
PhatA55's Avatar
Update: I'm getting fire. I hooked up my timing light and zip tied the trigger down. I watched it flash while I cranked the engine but it still won't fire. I don't have anyone to help so I can't check the marks while cranking. What could cause this to happen by turning the dizzy?
--Mark--
1979 RoW 930
1999 BMW Z3
Old 08-27-2006, 12:25 PM
PhatA55's Avatar
2nd update: I pinched off the vacuum line to the AAV and pulled the vacuum line to the dizzy advance and got it to start. It idled about normal but black smoke blew from the tail, I re-connected the dizzy advance hose and the smoke cleared up but idle dropped again. Anyone???
--Mark--
1979 RoW 930
1999 BMW Z3
Old 08-27-2006, 01:22 PM
PhatA55's Avatar
Ok, apparently its not an AAV, from what I've read its a "vacuum limiter" PN 930 110 173 00 according to PET. It also appears to be called a "deceleration valve" or "Auxiliary Air Device".
--Mark--
1979 RoW 930
1999 BMW Z3
Old 08-27-2006, 01:48 PM
PhatA55's Avatar
Here is the part in question:
--Mark--
1979 RoW 930
1999 BMW Z3
Old 08-27-2006, 02:44 PM
