Eye of the Toiger
matty74's Avatar
Gear shifter for a 915
Hi there,
Any of you guys replaced the shock shifter for a gated set up or aftermarket?
What's the best? I have seen some on eBay for around 1K seems a lot for a shifter.
I found one here as a buget option http://www.seinesystems.com/GateShift-1.htm
any one use the wevo shifter?
http://www.wevo.com/wevoshifter.htm
I'm about to do a box rebuild and want to get a new shifter along with it.
Whats the mid and top of the range any recommendations apprciated.
Matt
http://www.aircooled.com.au
1973 911 RSR clone powered by 77 3.0 turbo
Old 08-27-2006, 02:01 AM
Driving member
jester911's Avatar
I think the consensus here is the wevo is the best. I really want one but find it hard to spend $600 on it.
Having said that if I was buying a new shifter it would be a wevo.
Jerry
'86 coupe gone but not forgotten
Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason.
Old 08-27-2006, 03:22 AM
