-   -   Odometer 74 911 not working (http://forums.pelicanparts.com/porsche-911-technical-forum/300845-odometer-74-911-not-working.html)
IXLOR8 08-27-2006 04:36 AM
The speedometer is working, but the odometer is not.
What is the likely problem? What needs to be done to repair?
Oh Haha 08-27-2006 05:27 AM
The little gear on the odometer had broken. While it is a DIY task, I would recommend you send it to a reapir shop for service. Search on Hollywood Speedometer. They do great work.
Also, do a search here on Pelican for lots of useful info if you try it yourself.
IXLOR8 08-27-2006 05:42 AM
Cost
What does it cost to bebuild an odometer?
Oh Haha 08-27-2006 06:44 AM
I think HS charges around $100.00. You need to take the guage apart.
Like I said, it CAN be done at home but if you bend or break something it will cost more in the long run.
Yes, I tried it and ended up sending mine out.:(
