FenderGuy's Avatar
7:31 ring & pinion question?
My 1980 SC had the tranny rebuilt 2 years ago and they added the 7:31 ring & pinion.
Ok I know its for quicker starts but whats the difference between
7(205/50/15) & 8 (225/50/15) x15 Fuchs
Vs
7(225/45/16) & 9 (245/45/16) x 16 Fuchs
Which wheel combo would be a better choice for the above gearing? Street driving only
Frank
1980 SC Cab Conversion (sold)
1974 914 2.0 RIP rear ended
Looking for a 996 Silver Cab 2002-2004
Old 09-10-2006, 01:23 PM
IROC's Avatar
Well, the 225/50-15 is approximately 23.85 inches in diameter and the 245/45-16 is 24.68 inches, so the 225/50 is about 3% shorter than the 245/45-16. This means that you're seeing about a 3% difference in gearing as a result.
Another way to look at it is that a 7:31 is a 4.429:1 ratio. Going from 245/45-16s to 225/50-15s is about the same as changing the ring and pinion to a 4.56:1. Or, if you go the other way (from 225 to 245) it would be like a 4.29:1 ratio.
It's all "gearing", in other words.
IMHO, a 225/50-15 with a 7:31 in a later gearbox with a relatively short 5th gear is going to be too "short" of gearing for typical street use. I wouldn't want to drive that car on the interstate for long distances... Definitely go with the 245/45-16s.
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 09-10-2006, 01:35 PM
Elombard's Avatar
Hey Mike what is the equivalent 8:31 ratio. Just curious.
Fender was there a profound difference when they rebuilt your box with the new R&P?
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 09-10-2006, 02:07 PM
Zeke's Avatar
Yeah, it's at least 3%. Closer to 3.5, me thinks (and according to my calculator ). Now, someone multiply 3+% by the max torque and tell us what really happens! And, that's just with the tire difference. I have no idea how to factor the 7:31 vs. 8:31 difference, although it should be the same forumla.
Old 09-10-2006, 02:20 PM
FenderGuy's Avatar
Mike
I have no clue, this will be my first 911 (still on its way to me) , so I have no clue what the difference would be? I just know the car has 6 & 7 x 16 Fuchs and as soon as Al Reed does my 7 & 9 x16 Fuchs, they are going on. Wanted to see if there was a difference between 15's and 16's....
Frank
Old 09-10-2006, 02:23 PM
IROC's Avatar
An 8:31 is essentially a 3.875:1 ratio. Much taller than a 7:31. Simply divide the number of ring gear teeth by the number of pinion gear teeth to get the ratio...
Mike
Mike
1976 Euro 911
Old 09-10-2006, 04:11 PM
