Cruise control vacuum line?
Where do you connect the vacuum line that goes to the cruise control servo?
Thanks for your help.
Old 08-27-2006, 09:44 AM
Please help.
Where do you connect the vacuum hose of the cruise control servo of a 1985? Cannot find where it goes.
Old 08-28-2006, 01:24 PM
you don't have a PET diagram or a PDF diagram?
ill find you a pic in a minute
Old 08-28-2006, 01:30 PM
at the end of the yellow line is a three way connector with a tube on it, cruise servo vac line goes there
http://i3.tinypic.com/25uih3q.jpg
Old 08-28-2006, 01:39 PM
Jerry,
Thanks for the picture, I will look if I have this connection.
I checked at my Bentley manual and it does not have a diagram, it only mentions to disconnect this hose but it does not mention where should you connect it.
I did not check the PET, I will do so now.
Old 08-28-2006, 01:52 PM
