emac's Avatar
Valve cover gaskets
I had to replace my right lower gasket as it was dripping on the exhaust pipe. I used the green gasket. She still has a slight drip after a prolonged ride. I have re tightened the nuts but do not want to over do it. I didn't see that the valve cover was warped but am wondering if anyone has had luck with the silicone gaskets that are sold and are orange in color
Thanks in advance
Ernie 81 SC
Old 08-28-2006, 06:16 PM
I experienced a persistent oil leak from the left side valve cover (lower/exhaust).....tried the original type gasket, high $$$ silicone type and still had a leak. I have the original turbo type covers and I didn't think it likely that they could be warped, however, I finally took the "suspect" cover to a machine shop and much to my surprise, it was warped. I had it "decked" and I am now using a silicone bead gasket (I believe manufactured by Reinz) and so far I have had no leaks at all.
So, I would suggest that you have a machine shop check your cover for possible warping (if it's warped, no gasket will stop a leak)....if it can't be "decked", then I would suggest that you try a pair of turbo type covers. Use new nyloc nuts, clean up the mating surfaces real good and don't over torque the nuts (something between 6-7 ft.lbs should be more than enough).
Marc Morrison
1964 356C coupe
'89 911 coupe
2008 Honda Accord
2008 Ford Ranger
Old 08-28-2006, 07:00 PM
