retnug
Guest
Posts: n/a
power antennae
You help me once before with a targa bar question. Now I have another. My antennae doesn't seem to want to retract all the way. It stops at the last segment. It will go down if I help it but not by itself. Does anyone know if there is a good way to lubricate these or any other suggestions.
Gunter
'82 911SC Targa
Old 04-27-2000, 05:26 PM
stormcrow
Guest
Posts: n/a
There is a switch inside the unit which controls the retraction of the antenna
Sounds like you may have to take the antenna motor out and check it out. Mine wasn't working and I found water had gotten inside where the motor was and corroded the wires. Cleaned it up and it works like a charm. Hope this info helps
Regards
Old 04-27-2000, 07:38 PM
