Question Which brake fluid DOT 3 or DOT 4 (in 86' 911).
I used the search function...but thought I'd ask point blank. I'll be bleeding the brakes with a vacuum bleeder (mighty vac)....which brake fluid should I use...DOT 3 or DOT 4. I'd like to buy the stuff off the shelf at one of the local parts stores (any problems with this)?
Also, any suggestions while using the vacuum bleeder?
Thanks.
86' 911 Carerra
Old 12-29-2005, 04:52 PM
Virginia Rocks!
VaSteve's Avatar
If you're tracking it, DOT4.
Most people use the racing blue and racing yellow. Alternate between the two.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 12-29-2005, 05:19 PM
ATE is good. I suggest Motul RBF. It has higher wet and dry specs. A little more $$ though @ $10/liter. You might find it at your local cycle shop.
More brake fluid specs here.
Sherwood
Old 12-29-2005, 06:35 PM
Thanks....I think I'll go with the Castrol products.
Sherwood...thanks for the link, very helpful.
86' 911 Carerra
Old 12-29-2005, 06:58 PM
Wer bremst verliert
JohnJL's Avatar
Steve's point is a good one...its good practice to alternate between the 2 so you can tell when you're onto fresh fluid when you change next...just bleed until you see the new color...
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 12-30-2005, 03:06 PM
The word the last couple of years is that ATE Blue is being discontinued because of staining. DOT likes amber or whatever. If that's the case, there must be a huge supply of ATE Blue in warehouses as it seems to be readily available. Regardless, used fluid should be more amber than new fluid.
Sherwood
Old 12-30-2005, 04:53 PM
In 101 Projects it says silicone DOT 5 is not recommended for street use.
86' 911 Carerra
Old 12-30-2005, 06:02 PM
Wer bremst verliert
JohnJL's Avatar
I believe DOT5 is silicon-based. In road cars, OK for a long-term fill but mildly compressable and so not ideal for performance braking systems like ours.
Old 12-30-2005, 06:13 PM
Nine9six's Avatar
I will second the Motul RBF...
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 12-30-2005, 06:55 PM
Wer bremst verliert
JohnJL's Avatar
Sorry if I misinformed. But I know ATE Blue and Gold are tops, personally.
Old 12-30-2005, 07:30 PM
makaio's Avatar
Dot 5 is best for long term storage or show vehicles.
Dot 4 fluid is what you want for your Porsche. For everyday street driving any off the shelf DOT 4 from your local auto parts store will suffice. If you're going to the track or auto-x, go with one with a dry boiling temp like ATE Super Blue or others.
And make sure to flush it every two years if you don't bleed your brakes regularly. I have seen lots of brake problems due to lack of flushing the fluid. One of them was a fender bender accident that could have been avoided at work.
Old 12-30-2005, 09:40 PM
My partner in crime had some ATE Blue....I went with that, job completed!
86' 911 Carerra
Old 12-31-2005, 12:01 PM
I do the ATE blue/gold thing too. I do DEs and street driving. No problems in either venue.
Old 12-31-2005, 12:12 PM
Virginia Rocks!
VaSteve's Avatar
If you do DE's, flush it WAY more often than that! Our region requires it to be done within 180 days.
Old 12-31-2005, 12:29 PM
randywebb's Avatar
No matter how you use the car, flush it every 2 years at a minimum - regardless of how often you bleed the brakes.
UNless you bleed them so often that you are really flushing the whole system w/in 2 years... in which case you have a problem...
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 12-31-2005, 12:33 PM
sketchers356's Avatar
OK, I'm missing something. I thought that the difference between DOT 3,4,5 was that with increasing number came increasing boiling point. So why would we definately not want 5?
Alexander
'75 911S Targa
'86 951 SOLD
Old 12-31-2005, 02:21 PM
OK...lotsa dancing around the issues here....
"Most" DOT 5 is silicone based. Good for long term storage. Will not absorb water which is the reason to replace other types of fluid. Small amount s of water absorbed ( 1-2%) can lower boiling points by several hundred degrees F. But, has an affinity for air, cannot get a "solid" pedal with it. Also requires "complete" draining and cleaning of the original system, since it is not compatible with other fluids. Big hassle.
There are *some* DOT 5 fluids that are NOT silicone, but these are very rare and terribly expensive...like a factor of 10X. I *think* ( help here, please...)French MOTUL has such brake fluid. I also *think* these are ESTER based and not silicone based....someone help here ?
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 12-31-2005, 02:30 PM
vash's Avatar
a racer guy told me the ATE stuff was to be used in racing applications where the fluid is really changed out often. he says it is more hydroscopic than stuff designed for the street. i have ATE gold in my car now. i may search out that MOTUL stuff, at cyclegear.
poof! gone
Old 12-31-2005, 04:05 PM
Maybe true, but frequent brake fluid changes are a good idea imo. One advantage is the bleeder nipples won't corrode shut if you excercise them on a regular basis. With a power bleeder, it's a very quick job.
Old 12-31-2005, 05:03 PM
"There are *some* DOT 5 fluids that are NOT silicone, but these are very rare and terribly expensive...like a factor of 10X. I *think* ( help here, please...)French MOTUL has such brake fluid. I also *think* these are ESTER based and not silicone based....someone help here ?"
Motul 5.1 is a polyglycol-based fluid and has a DOT spec of 5.1 to differentiate itself from the DOT 5, silicone-based fluids. Motul RBF has a DOT 4 spec.
In my earlier post on the cost of RBF, it's about $26 per liter. ATE and Motul 5.1 is about $10/liter.
Sherwood
Old 12-31-2005, 05:29 PM
