Allan Broadribb
Guest
Posts: n/a
Transmission leak
I have a 1970 911E coupe which has taken to leaving a few drops of transmission oil on the floor. I jacked it up put it on stands and rolled underneath to find oil on the front engine/transmission support. It looked like it was coming from a fitting on the right side of the transmission and to the rear of the support - is this the speedometer cable, I can't find a picture of the transmission that shows it. Anyway, pushing this object showed it to be a little loose and there was no room to get a wrench on the nut at he base of it.
I guess my questions are - is this the speedo cable and if so how do you tighten whatever it is without lowering the transmission
Old 05-02-2000, 09:53 AM
