Weston
Guest
Posts: n/a
81' 911SC brake light won't go out
I was driving and the brake light came on. I have blead down the brake system and still no luck. Is there a reset somewhere? I even took the emergency brake apart. no luck.. Frustrated......
Old 05-01-2000, 05:19 PM
dw89
Guest
Posts: n/a
Check the brake sensor
Old 05-01-2000, 06:03 PM
retnug
Guest
Posts: n/a
If you are talking about the dash brake light I had the same thing happen. My mechanic pulled out the clock reached in behind the light and unplugged it, waited a minute and then plugged it back in. This did the trick. Apparently, as strange as it may sound this works. Try it and report back.
Old 05-02-2000, 07:19 AM
Weston
Guest
Posts: n/a
Where is the brake sensor located?
Old 05-02-2000, 10:11 AM
