-   -   RSR tail lights..do you ?? (http://forums.pelicanparts.com/porsche-911-technical-forum/301990-rsr-tail-lights-do-you.html)
afterburn 549 09-01-2006 02:18 PM
"R" tail lights..do you ??
How many have installed these light weight babies and which vendor did you use, and of course there are a couple of diff styles...so your input and a pic ??http://www.pelicanparts.com/support/smileys/hiding.gif
ZLP 09-01-2006 02:30 PM
I think you mean R instead of RSR. RSR's used regular lenses.
Formerly Steve Wilkinson 09-01-2006 02:40 PM
I got mine from MotoDelta (moto-delta.com) in Illinois. The fiberglass pieces were of high quality and light, but the reason I bought them was because the lights are LEDs, not just to save a few pounds (which they definitely do). $258 inlcuding shipping and an extra-cost mounting piece. You have to paint them, of course.
Stephan
afterburn 549 09-01-2006 02:54 PM
OK "R" lights, thanx
John Z. Goriup 09-05-2006 05:57 AM
I think you'll have the best results by contacting Mike Bazaglou (hope I spelled that correctly) at TRE in North Hollywood for the "R" lights you seek. His company distributes front and rear R lights that are built by Mike Swanson and are without question the finest and most authentic reproductions out there with the best fit. Naturally, you can expect to pay slightly more than the price you mentioned but quality and cheap are simply not compatible,....ever. Your biggest challenge will come in successfully scoring the correct front and rear Hella lenses that are authentic, rather than the approximate reproductions for sale. This week however is German Auto Fest, and I'd get my ass to Ventura if Porsche figures into your daily life, for surely there you will find most of what you need.
Good Luck
John Z. Longhoods 4ever
Formerly Steve Wilkinson 09-05-2006 06:44 AM
It's Dave Bouzaglou.
Stephan
afterburn 549 09-05-2006 07:13 AM
thanx..exact repro is not a criteria just need a light thats light and cool
cstreit 11-16-2006 06:20 AM
Originally posted by John Z. Goriup
/... finest and most authentic reproductions out there with the best fit. Naturally, you can expect to pay slightly more than the price you mentioned but quality and cheap are simply not compatible,....ever. John Z. Longhoods 4ever
John,
I'm sure you didn't mean it this way, but you're implying that the fiberglass lights I carry are not of the highest quality. I would challenge that strongly. The fiberglass panels are impeccable and there are plenty of people around here that have them to attest to that.... No one that has installed them has had to refinish or "massage" them for fit at all.
The LED lights are not only of very high quality, they are also the only LED lights out there that are DOT approved, so for all the guys with state inspections we can provide the DOT certifications to show the inspectors. No problem.
afterburn 549 11-16-2006 06:29 AM
I will vouch for ya cstriet. The fit is purrrffect, no problem, as for the little f.g. do dad shim you were talking about..I have no idea what it would do or why it would be necessary, as the fit is right pronto. No problem. No massaging, no grinding and re do, drill the two holes,
( shown clearly on them ) adjust the metal backing plates on the car and screw them on. Ya might want to paint them.....i did
Formerly Steve Wilkinson 11-16-2006 06:37 AM
Me too. Mine are of the highest quality.
thrown_hammer 11-16-2006 08:49 AM
I bought mine from Ray who I believe now supplies Chris. They are very high quality. If you don't need a perfect restoration correct part and are just wanting the look. They are the way to go. And by the wayI invented R lights. (not the crappy ones Mark Wilson stole off a tractor either...)
k9handler 11-16-2006 09:22 AM
I am another guy who can tell you the moto-delta set are perfect. :D
http://forums.pelicanparts.com/uploa...1163701176.jpg
http://forums.pelicanparts.com/uploa...1163701359.jpg
rouxroux 11-16-2006 10:03 AM
The only reason I did not get mine from Chris is because I wanted a "combo" amber/clear so I could have turn & back-up in 1 unit instead of having to fab up something else for back-up. I wound up buying mine from Pelican. . http://forums.pelicanparts.com/uploa...1163703816.jpg
Dutchie 11-16-2006 10:41 AM
Mine are from Mike Swanson (AR Concepts) and the fit is perfect.
http://www.pelicanparts.com/pmpre/im...1133776317.jpg
thrown_hammer 11-16-2006 10:43 AM
Ed,
That car is by far one of my favs!
Porsche virgin 11-16-2006 11:39 AM
Are these units really that much lighter than the stock ones?
randywebb 11-16-2006 11:43 AM
aka TRE Cup - his posting name
The stock units weigh 7.4 lbs ('73.5 911) for a pair. The R type ones save 5-6 lbs. at the extreme rear of the vehicle corners (where wt. savings has the max. effect on yaw; less so on roll or pitch since they are not that high off the ground). The savings is primarily due to the heavy cast metal housings P AG used on their lights -- LEDs will save little wt. over the bulbs and thin metal bulb sockets.
If you have not added a light wt. deck lid then the benefit is mainly cosmetic. If you have done that it is worthwhile - esp. if you have subbed ext. hinges, rubber tie downs for the latch mech., light mesh grill as on R types, and so on.
I don't like the gap they leave in the body colored areas (hard to see on dark cars) so am holding out for ones that take the stock lenses.
You need to retain backup lights - do a search.
thrown_hammer 11-16-2006 12:01 PM
Yeah Randy, Dude would have to be crazy to go that far...:D
http://forums.pelicanparts.com/uploa...1163710875.jpg
dd74 11-16-2006 01:10 PM
The stock units weigh 7.4 lbs ('73.5 911). The R type ones save 5-6 lbs.
Is that weight you quote for each tail light unit, or for the pair?
randywebb 11-16-2006 01:49 PM
pair - will edit above
nice street car, Shawn...
I hope you ditched the rear glass for a plexi backlight...
