found a loose vacum tube- where does it belong?
Today while changing fuel filter I found a cloth covered vacuum tube. NOT the Blk & Red ones that go to the distributer but similar. It goes.....somewhere on the left side of the engine bay in the rear... but where? Will post photo's tomorrow if needed.
I also discovered a there is a missing nut (!!!) on the valve cover. Just one of those days. By the way, the fuel filter is a beyatch to disassemble. Much easier on other cars I own, BMW & VW. The connectors are way too tight...and the space is limited. The down-side to changing the fuel filter on the M3 is that you have to jack the car up and gas invariably spills on your face... Almost prefer that to the P-car which is usually a joy to work on...
jt '83 SC '96 M3 6 Bicycles 2 Sailboats |
cruise control vacuum lines - 1 big cloth covered and 1 small cloth covered.....(?)
makes sense, thank you....
Friend of Warren
If it is the bigger of the two hoses to the cruise control then one end should be connected to the cruise control and the other end stays open and tucked into the opening of the frame between the two shock towers.
Kurt V No more Porsches, but a revolving number of motorcycles. |
If you're not using the cruise control, then plug the small hose. Otherwise you have a vacuum leak on your intake, which messes up the idle speed.
Jeff 1981 911SC Coupe - SSI's + Dansk, MSD, AC delete, Heater Backdate, Euro ride height, polygraphite bushings, Rennshift 1998 F-150 4x4 - Snow Time 1998 Yamaha WR400 - Mountain Ride |
Vacuum Tubes - really?
oh! you mean vacuum hose!
Had me going there, I haven't come across a vacuum tube on my 911 and was thinking I should have found this somewhere:
1980 911SC - 2nd Rebuild in Process - 2005 Porsche Cayenne Turbo - 2013 VW R ________________________ 2000 BMW X5 - 1996 BMW 530i - Toy 4 Runner (x2 or 3) - 1987 Toy Supra - 1988 Honda Si - 1984 El Camino Super Sport - MGA - MGB - Fiat 124 Spyder - Fiat 128 Wagon - 1962 Karmann Ghia - 1951 VW - 1953 Willys Jeepster w/Chevy 286 - 1995 Volvo 960 - 2006 VW GTI |
lol..goldgunner beat me to the punch!
![]() ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008 www.friendsofwarren.com 1990 964 C4 Cabriolet (current) 1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold) |
hey kid wanna buy some new old stock 6L6's
Peace, Ron www.ronorlando.net 78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk Own a gun and you can rob a bank , own a bank and you can rob the world. |
