76 Fenders on a 72 911???
Does anyone know if fenders from a 1976 911 will fit on a 1972 car?
Thanks,
Jason
1972 911T MFI
1995 911 C2
Old 10-11-2006, 09:11 AM
DP935 member
kycarguy 935's Avatar
76 are not the right ones for a 72. You need 69-73 fenders for a 72. Goodluck.
p.s. Most of the 76 fender will actually bolt up to most of the 72 body but is missing some needed fender metal in the front.
Porsche Slantnose M505 M506 group on Facebook.
https://www.facebook.com/groups/719995181372494/
Old 10-11-2006, 09:59 AM
kc carguy is right if you're talking about front fenders. if you were referring to rear quarterpanels then they will work, with the exception of the missing hole and hardware to accomodate the '72 oil tank in the RH side.
Michael
Sans Porsche...for now
2009 Mazdaspeed 3 Grand Touring daily driver / DS autocross toy
2010 Subaru Forester X Limited - wife's daily driver
Old 10-11-2006, 10:07 AM
Carbon Emitter
jkarolyi's Avatar
You can make a 76 fender work if you weld on the lower turn signal housing section from a 69-73 fender. I can cut this off of an extra passenger side fender. if you want it.
Old 10-11-2006, 10:53 AM
Ok thanks, I thought it would not fit. Some one had one for sale. Hay Jay, is the one you have in good shape?
1972 911T MFI
1995 911 C2
Old 10-11-2006, 12:36 PM
Carbon Emitter
jkarolyi's Avatar
It is amazingly rust free in the usual problem areas, but it has some minor dents and thick paint. It's definitely savable but needs to have the paint stripped off and a few dents worked out. It's yours for $100 if you can come pick it up in Riverside.
Old 10-11-2006, 02:01 PM
