rteague's Avatar
interior door handle replacement
I know this is supposed to be very routine. Trust me I could break a steel ball. My 84 m491 has those cheap-ass plastic door handles. I purchased 2 aluminum handles. My understanding is you pry out actuating rod from handle (lift up and out). Then remove pocket perimeter. You remove clip holding handle onto the rod. Install is reverse. This sounds way to easy for me. Will I lose the actuating rod inside of door panel once removed from handle? Vise grip the rod first? thanx r.t.
Old 09-02-2006, 01:19 PM
ecm911's Avatar
rteague,
Its as easy as you think. Been a while but have done it many times - in many cases the rod will come out with just you fingers. No you will not loose the rod in the door. Pretty straight foward.
If my memory is correct that's the easiest part of the job.
Good luck.
Earl
78 SC Coupe
93 RSA (Gone)
Old 09-02-2006, 01:29 PM
Which Aluminum handles did you get?
Old 09-02-2006, 03:44 PM
rteague's Avatar
got them through performance auto. r.t.
84 m491 blk/blk coupe
1st Place The Ventura Show
September 9 2006
Last Place The Ventura Show
September 10 2006
Old 09-02-2006, 03:57 PM
Back in New England!
MattAlpha's Avatar
Send a message via AIM to MattAlpha Send a message via MSN to MattAlpha
I think buffjamr was asking if you got the polished aluminum ones or the black painted ones.
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip!
Old 09-02-2006, 06:59 PM
rteague's Avatar
black. my interior is all black and plastic stock were black. got them on and didn't have to call my mechanic although the clips old and new didn't fit the handle. aluminum about 1/16 in too thick. had to file down bottom of handle where the clip went through. I also screwed up some things but fixed them. r.t.
September 9 2006
September 10 2006
Old 09-02-2006, 07:06 PM
User
ikarcuaso's Avatar
rteague, can you provide a link to where you got your handles? Is it one of these?
http://www.***************/productpage.aspx?pid=103519&name=Inner%20Door%20Handle&part=101375
http://www.***************/productpage.aspx?pid=100705&name=Aluminum%20Inner%20Door%20Handles&part=S11665
Thanks.
82 Targa
Old 09-02-2006, 10:45 PM
rteague's Avatar
exactly. I have seen some really cool ones with th porsche emblem. Does anyone know about these?
September 9 2006
September 10 2006
Old 09-02-2006, 11:13 PM
There was a set with the emblem on ebay not too long ago. I've seen some others on ebay for like $40 a guy makes that are really nice. You can get them slotted or drilled but he hasn't listed them for a long time and I misplaced his user name.
1989 Carrera Targa - - Guards Red
Old 09-03-2006, 09:34 AM
