Installed Priority Start and power port, suggestions?
I am working on my electrical system and decided to add a few items. So far I added the Priority Start to ensure the battery is not drained by some dumb move I might make in the future. I also added two switched power ports so I can run 12v accessories like my iPod and GPS at the same time. Next on the list is a kill switch...suggestions on mounting location and what guage wire to use from the battery to the kill switch?
Also any of you guys had issues with the Priority Start system? I have it installed and seems to be working fine, just wondering. Best part of all these add-ons is they were free, added up the items and it's over $135 of freebie stuff. :D |
- connect the GPS & iPod together so your location determines what tune plays...
ha ha that would be cool.
you might put a relay in there and just run a thin wire to the switch - check your rules to see if that's allowed
I usually see these mounted as flapper bars on the fender (the guy running up to put out the fire &/or remove the corpse can flip it - not the driver....) |
thanks Randy...I was thinking in the place of the antenna, but some metal fab would need to be done as the kill switch/removable key is larger than the opening. Then again I would need to remember to take the key with me so in the car may be better...top of dash in the old speaker grill location was a thought.
| All times are GMT -8. The time now is 04:07 PM. |
