 adding euro trans cooler? I have a line on a 915 euro trans cooler, diff plate and oil pump.  what all is involved in adding a euro cooler to a non euro 84 915?  Do I need more parts?  Is is "bolt on" or does it require disassembly of the entire trans?  any help / advice is helpful... |
 HI if all the parts are there in the side plate; gears, oil pressure ball & spring, inner drive gear, you will also require the Ally gear off the diff with the 2 bolts to drive the pump, on the out side the oil cooler loop with the retaining clip AND the gearbox center case as the oil cooler feeds the oil back into the box through the hole in the side, there is also a small guard to go under the cooler, if you have the PET 5 or 6 look at 911, 1986, transmission, page 302-01 it has the picture of the pump and parts. regards mike |
| All times are GMT -8. The time now is 09:28 PM. |
