1985 930 Electrical Issues
Last night when driving home something happened that I need to track down. My highbeams popped, my parking lamps perished, and I was left with only low beams to make it home. When I got home, I went to check the fuses under the hood and heard my optima battery hissing. It was extremely hot. As if it was overcharging. Before I go and tear this system down looking in every direction, does anyone have a good idea where to start or what may be the cause of this? Any help would be greatly appreciated.
Old 08-26-2006, 12:14 PM
voltage regulator bizerk. just get a fresh alt/reg unit and replace the old one.
206 637 4071
Old 08-26-2006, 12:16 PM
Early_S_Man's Avatar
Porsche Crest
JW already gave you the solution, but I would like to suggest that you install an expanded scale Voltmeter so you will be able to track your system Voltage and be better informed of problems as they occur. Pelican has a very good VDO Cockpit series expanded-scale Voltmeter.
You will probably need to replace the Optima battery ... there is a warning/caution about charging them above 15.5 Volts at the Optima web site.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 08-26-2006, 01:01 PM
I was told that this may also be a grounding issue? I know it was a votage regulator issue, I just didnt know if other causes may be attributable. The car battery intermitantly discharges overnight prior to this mishap. Sometimes it would happen, others it would not. I think there may be more to this story and wanted to know of others that may have heard or have had similar electrical issues. Thanks.
Old 08-26-2006, 01:38 PM
Bump! Bump!
Old 08-26-2006, 05:36 PM
Big Old Bump!
Old 08-27-2006, 09:23 AM
Porsche Crest
While I have no doubt that grounding issues are possible, they would tend to cause low output Voltage, rather than high. If a Voltage regulator 'sees' a higher-than-normal' Voltage drop because of a high-resistance ground, then the battery would 'see' a lower-than-normal applied Voltage, not 18 Volt++ cooking levels.
It would certainly be a good idea to clean up the battery posts, grund strap connections in the trunk, body-to-transaxle, and engine compartment ... before the new alternator is tested!
Warren Hall, Jr.
Old 08-27-2006, 09:38 AM
Warren.....
what would constitute an "expanded scale" voltage meter as opposed to regular scale???
8V-16V ... ????
- Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 09-03-2006, 11:34 AM
