My first 3.2, starting issue
So....cranking the motor, starts and immediately dies.....what do I adjust?
Stepping on the throttle while cranking does nothing....bump starts and runs immediately.... |
You don't have it listed so not sure if it is a stock Carrera, something with a stock Motronic driving it, or some sort of Frankenstein abortion thing with carbs, MFI, or CIS on it...
One thing is that a Motronic car is supposed to be started with no throttle input. Just turn the key. |
Yep....it's stock...but it's in a 914/6. LOOKs like I have it narrowed down to an issue with the ignition switch.
DME relay??You may want to check into that I have replaced those to cure the same problem
| All times are GMT -8. The time now is 05:01 AM. |
