Do I need a special tool
Do I need and/or where can I buy the special tool mentioned in Waynes book and the Bently manual to remove these nuts.
Cars an 87 3.2 I can't seem to find the tool on the website. Thanks Brian
1987 911 Coupe-Current ride 2007 997TT-Sold 2006 997 C2S-Sold 1991 964 Turbo-Sold 1987 911 Targa-You never forget your first |
From Pelican. Cam bar; about $100. Call if you can't find it on the site.
ianc Edit: PEL-TOL- P237 - $72
BMW 135i. Nice. Fast. But no 911... "I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79 Last edited by ianc; 08-28-2006 at 11:25 PM.. |
Brian,
Timing chain on the left side is pretty close to the limit for wear. Can't see enough of the right side. I'm confident with a picture showing the position of the tensioner arm, would indicate time for replacement.
DOUG '76 911S 2.7, webers, solex cams, JE pistons, '74 exhaust, 23 & 28 torsion bars, 930 calipers & rotors, Hoosiers on 8's & 9's. '85 911 Carrera, stock, just painted, Orient Red |
Senior Member
I threw a wire around the chain near the sprocket to ensure it does not move or skip a tooth, then lock the flywheel and turn the nut. Easier if you use a pneumatic wrench.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Wer bremst verliert
If you hold the crank (I used a long screwdriver as a lever between two bolts on the crank pulley) you don't need the tool. Just hold the crank still while you loosen the cam bolt. Works for installing too.
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
Gentlemen,
The following pictures show what a new timing chain looks like. Notice the position of the tensioner shaft and how close things are to the chain housing when stretched. The stretched chain really should have been changed sooner. With these two images to compare to, it is rather simple to determine relative chain stretch.
the only tool you need is the cam holder when you tighten the bolt. a short tube with 3 pins to enter the sprocket holes and a bar handle. a deep 19mm socket goes through it to tighten the bolt. yes, the chain worn, so that pretty much tells you that both of them are. easier to see it on the left side.
Wer bremst verliert
John,
Is my method the "Sanford and Sons" approach? ;-)
John,
Although your method seems to work, it does so by putting a significant load against the intermediate shaft gears, bearings, sprockets and the new timing chain. The entire camshaft drive. More load than designed for. By holding the cam sprocket at the sprocket, excessive loads through the cam drive system are avoided. I'm sure you agree, holding the sprocket while tightening the retaining bolt avoids potential future problems.
didn't i just describe the cam holder tool?
Back in New England!
Can someone post a picture of this tool.
It would be nice to see, since I'm sure I'll be replacing my chains in the next two years, or when my first engine drop is required. Thanks, Matt
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip! |
Somatic Negative Optimist
Matt:
ianc told you what the tool is. Cam Bar, 911 (1980-89) [Photo] PEL-TOL-P237 $72.00 You can do some search yourself, it's easy! If anyone plans to only change the chain without changing the sprockets on the intermediate shaft, go here: New chains without new sprockets? Read this! Brian: Aside from the cam holder, you would also need the Z-block and dial indicator for timing the cams. It's more involved than you think. Why do you want to open the center bolt on the cams?
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
I've got four broken head studs
I just finished building a SS 3.2 and recommend that you buy the right tools. You can always sell them after.
A quality 3/8-drive torque wrench is a must! So is Wayne's book on engine rebuild. Z-block, dial indicator, cam bar, ring compressor, To replace the studs, the P/C's have to come off, of course. Hopefully, you'll find Nikasil to re-ring. Depending on the mileage, the top land may still be in spec. If you find Alusil, you have to make a decision: Take a chance and re-ring or get new P/C's.
Gunter thanks for answering my question that Ianc had already answered. I was just hoping that someone had a picture of their own while using it. Just helps me see the best way to use it (orientation wise on the cam spocket).
-Matt
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
BMW 135i. Nice. Fast. But no 911... "I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79 |
