Tom '74 911's Avatar
Carbon Monoxide/Exhaust testing?
I think I may be getting some exhaust in the cabin thru my heat exchangers - when I turn on the heat - but I'm not sure. I bought a battery powered carbon monoxide alarm, like what you'd use in your house, and have been driving around w/it on my dash. It hasn't beeped yet, but I don't trust it. I know this is serious stuff, so I'd like to know for sure if I'm going to pass out while driving on the highway when I turn my heat on. Is there a testing device that I could hold up to my heater vent that would tell me w/absolute certainty if there's exhaust comming through? And who might have such a device (that would be willing to let me borrow it from them - even for a small fee?) Might a garage or mechanic have something that would work?
Thanks,
Tom
'74 911 Red Sunroof Coupe, 3.6L, etc...
'76 912 Yellow SPEC 911/911CUP
Old 11-01-2006, 10:40 AM
JTO JTO is offline
Just a data point: my '75 S had 5 ppm CO in the cabin at idle with the heat on. This was before the complete rebuild, but since it appears you have factory original HEs, as I did, it may be reasonable to assume you do have CO in your heated air. I borrowed an atmospheric quality tester fro work (for confined space entry) to do my check. Maybe an environmental/industrial hygene outfit in your area could do a quick check for you.
Troy
Troy
Past: 1975 911S Silver Anniversary-rebuilt and sublime.
Past: 1988 Carrera-backdated with a 3.6 and all the goodies.
Present: 2011 GMC 2500HD with the 6.0 & 4x4!, 2004 Toyota Sequoia (wife's)
Old 11-01-2006, 10:53 AM
Automotive Monomaniac
Emission's Avatar
Try putting the CO detector by your head. My dash gets a flow of fresh air all of the time through the defrost vents...
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order)
Old 11-01-2006, 11:19 AM
Troy
What is an acceptable reading? Should it be 0 and nothing more, or is 5 ppm OK?
Thanks,
Tom
Old 11-01-2006, 11:45 AM
JTO JTO is offline
Should be zero. Five PPM is high to me but I don't know what the TWA (federal time weighted average) is off hand.
Troy
Troy
Old 11-01-2006, 12:11 PM
