78 STROSEK's Avatar
3.0 turbo case
I have a 77 3.0 turbo motor with a bad case. Is this the same as a n/a 3.0 case? What is the difference in the 3.3 case?
Old 09-06-2006, 05:35 AM
boba's Avatar
It is not the same as a n/a 3.0lt. It is the same as Euro 3.0lt Carrera. The dif is the journal size.
Old 09-06-2006, 06:03 AM
78 STROSEK's Avatar
Can the journals be machined to work with the turbo crank?
Old 09-06-2006, 07:52 AM
78 STROSEK's Avatar
What is the part # for the euro case?
Old 09-06-2006, 10:08 AM
aseem's Avatar
Case number is 930/02. Dont have the actual part #
Arnljot
1980 930 GT35R, TurboKraft IC, 965 P&C, 964 Cams, Tial WG, ported heads, BLWUR, RarlyL8 hdrs&mfflr, Zeitronix logger & wideband
1989 928GT
1972 BMW 3.0S
Old 09-06-2006, 11:16 AM
typ 911
Bryan Beaumont's Avatar
Contact Henry at SuperTec. He is usually looking for 3 liter turbo cases and will be able to help you out with whatever it is you need to make yours work for your needs. 760-728-3062.
'74 911-Not Stock...
typ911@gmail.com
Old 09-06-2006, 12:47 PM
