When I started to pull of the chain housing covering I was expecting some oil to pour out of the case. But, to my surprise there was very little oil in there. The chain seems well lubricated and indicated no wear. Is this normal? Where does the oil come into the housing and where does it drain out to?
Thanks John 3.2 Carrera |
Have you drained the oil from the engine?
Which side did you remove? Onky one side, the right I think, will have some oil if the engine is drained.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
Yes, all the oil is drained from the engine. But I am surprise that I don't that much oil in it. I would expect to see oil contained like in the valve cover. After I removed the valve cover there was plenty of oil dripping out. When I remove the chain cover there weren't any oil dripping in there. Hmmmmmm??
there is very little oil in the chain housing because the rest came back into the engine block
1972 911T 1991 Mazda RX-7 Turbo II Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life! |
right side drools way more than the left.
