-   -   Idle Hunting Problem (http://forums.pelicanparts.com/porsche-911-technical-forum/303088-idle-hunting-problem.html)
Gunter 09-10-2006 07:48 AM
AAR - Auxillary Air Regulator
AAV - Auxillary Air Valve
WUR - Warm Up Regulator (Also called Control Pressure Regulator)
CSV - Cold Start Valve
FD - Fuel Distributor
CIS - Continuous Injection System
CDI - Capacitance Discharge Ignition
You also have a deceleration valve, throttle switch, air flow sensor switch, frequency valve, acceleration enrichment control unit, Lambda Emission Control, and a pile more sensors on your engine.
Shocking, isn't it?
Get the Bentley SC Repair Manual, you'll love it.
It explains how these components function.
ruf-porsche 09-10-2006 07:58 AM
Find yourself a mentor on this forum. List your location. I'm sure a fellow Pelican can help you.
russell83 09-10-2006 11:29 AM
It's impressive and shocking...thanks guys for taking the time!
911 Rod 09-11-2006 07:11 AM
Let's not forget about the ICV (Idle control valve)
Gunter 09-11-2006 07:20 AM
No ICV.
He has an SC with CIS, not a Carrera with DME. :)
911 Rod 09-11-2006 07:43 AM
Originally posted by Gunter
No ICV.
Point taken.
I posted this because a few Carrera guys have chimed in with the same problem. I should have been more specific.
I'll be taking my 86 Carrera in for a CO check etc to Tuesday and will keep everyone posted.
Rod
