-   -   How to tell if you have an exhaust leak or valve noise (http://forums.pelicanparts.com/porsche-911-technical-forum/30317-how-tell-if-you-have-exhaust-leak-valve-noise.html)
jryerson 05-15-2000 08:51 PM
My SC has developed a tick on the drivers side when it gets warmed up to about 220'
I believe its either valve noise or exhaust leak
How can you tell if its a exhaust leak?
Early_S_Man 05-15-2000 10:39 PM
I'm not sure how to describe the difference, other than to say valves are a more metallic, ticking sound, and exhaust leaks are more like a 'spitting' sound ...
Of course, the 'cute' answer is, if you adjust your valves and the mystery noise goes away ... then it wasn't an exhaust leak!
Warren Hall
1973 911S Targa
jryerson 05-16-2000 10:37 AM
Thanks Warren
It was a metallic sound so I re adjusted my exhaust valves solved the problem
jryerson 05-16-2000 03:15 PM
PS I picked up a mechanics stethascope at Pep Boys for $15 - it was real handy to locate which rocker was making all the noise along with other uses
